Компактное аудиорешение Nuvoton NSP2340BA24E
Datasheet DILM115(RAC240) - Moeller Даташит CONTACTOR, 3 POLE, 55KW — Даташит
Moeller DILM115(RAC240)
Наименование модели: DILM115(RAC240)
Производитель: Moeller
Описание: CONTACTOR, 3 POLE, 55KW
data sheetСкачать Data Sheet
Type: DILM115(RAC240) Article No.: 239548 Sales text Contactor,55kW/400V,AC operated
Ordering information Connection technique Description Description Rated operational current AC-3 380 V 400 V Max.
rating for three-phase motors, 50 ­ 60 Hz AC-3 220 V 230 V AC-3 380 V 400 V AC-3 660 V 690 V AC-4 220 V 230 V AC-4 380 V 400 V AC-4 660 V 690 V Conventional free air thermal current I th = I e AC-1 at 60 °C Open Contacts Can be combined with auxiliary contact DILM150-XHI(V).. DILM1000-XHI(V).. Ith = Ie A 130 P P P P P P kW kW kW kW kW kW 37 55 90 17 28 43 Ie A 115 Screw terminals 3 pole Springloaded terminals on the auxiliary and control circuit terminals
1
Actuating voltage Contact sequence
RAC 240
  • Тип реле: Contactor
  • Contact Configuration: 3 N/O
  • Внешняя длина / высота: 170 мм
  • Внешняя ширина: 90 мм
  • External Depth: 176 мм
  • Contact Current AC Max: 115 А
  • Contact Voltage AC Max: 400 В
  • Mounting Type: DIN Rail / Panel
  • No. of Poles: 3
  • Approval Bodies: IEC/EN 60947, VDE 0660, UL, CSA
  • Coil Voltage Max: 240 В AC
  • Dielectric Voltage Coil to Contact: 440 В AC
  • Dielectric Voltage Contact to Contact: 440 В AC
  • IP / NEMA Rating: 00
  • Insulation Voltage: 690 В AC
  • Main Contact Current AC3 Max: 115 А
  • Power Rating: 55kW
На английском языке: Datasheet DILM115(RAC240) - Moeller CONTACTOR, 3 POLE, 55KW
Политика конфиденциальности
