Datasheet DILM12-01(24VDC) - Moeller Даташит CONTACTOR, 5.5KW, WITH 1NC AUX — Даташит
Наименование модели: DILM12-01(24VDC)
Производитель: Moeller
Описание: CONTACTOR, 5.5KW, WITH 1NC AUX
Type: DILM12-01(24VDC) Article No.: 276880
Ordering information
Rated operational current AC-3 400 V Max.
rating for three-phase motors, 50 60 Hz AC-3 230 V Max. rating for three-phase motors, 50 60 Hz AC-3 400 V Max. rating for three-phase motors, 50 60 Hz AC-3 690 V Max. rating for three-phase motors, 50 60 Hz AC-4 230 V Max. rating for three-phase motors, 50 60 Hz AC-4 400 V Max. rating for three-phase motors, 50 60 Hz AC-4 690 V Conventional thermal current I th = I e AC-1 Open For use with Ie P P P P P P Ith = Ie A kW kW kW kW kW kW A 12 3.5 5.5 6.5 2 3 4.4 20 DILA-XHI(V)..
General
Standards Lifespan, mechanical AC operated DC operated Operating frequency, mechanical AC operated DC operated Climatic proofing Ambient temperature Open °C -25/60 Operations/h Operations/h 9000 9000 Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclical, to IEC 60068-2-30 Operations Operations Ч 106 Ч 106 10 10 IEC/EN 60947, VDE 0660, UL, CSA
- Тип реле: Contactor
- Coil Voltage VDC Nom: 24 В
- Внешняя длина / высота: 68 мм
- Внешняя ширина: 45 мм
- External Depth: 125 мм
- Contact Current AC Max: 12 А
- Contact Voltage AC Max: 400 В
- Mounting Type: DIN Rail / Panel
- No. of Poles: 3
- Approval Bodies: IEC/EN 60947, VDE0660, UL, CSA
- Coil Voltage Max: 24 В DC
- Dielectric Voltage Coil to Contact: 400 В AC
- Dielectric Voltage Contact to Contact: 400 В AC
- IP / NEMA Rating: 20
- Main Contact Current AC3 Max: 12 А
- Power Rating: 5.5kW
DILM1201(24VDC), DILM12 01(24VDC)
