Datasheet DILM12-10(24VDC) - Moeller Даташит CONTACTOR, 5.5KW, WITH 1NO AUX — Даташит
Moeller DILM12-10(24VDC)
Наименование модели: DILM12-10(24VDC)
10 предложений от 4 поставщиков
Контактор: 3-полюсный; NO x3; Вспомогательные контакты: NO; 24ВDC
DILM12-10-EA(24VDC)
Eaton Cutler Hammer
от 8 849 ₽
Зенер
Россия и страны ТС
DILM12-10-EA(24VDC)
от 9 134 ₽
DILM12-10-EA(24VDC)
Eaton
от 9 371 ₽
TradeElectronics
DILM12-10-24VDC
Производитель: Moeller
Описание: CONTACTOR, 5.5KW, WITH 1NO AUX
data sheetСкачать Data Sheet
Type: DILM12-10(24VDC) Article No.: 276845
Ordering information
Rated operational current AC-3 400 V Max.
rating for three-phase motors, 50 ­ 60 Hz AC-3 230 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-3 400 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-3 690 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-4 230 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-4 400 V Max. rating for three-phase motors, 50 ­ 60 Hz AC-4 690 V Conventional thermal current I th = I e AC-1 Open For use with Ie P P P P P P Ith = Ie A kW kW kW kW kW kW A 12 3.5 5.5 6.5 2 3 4.4 20 DILM32-XHI.. DILA-XHI(V)..
General
Standards Lifespan, mechanical AC operated DC operated Operating frequency, mechanical AC operated DC operated Climatic proofing Ambient temperature Operations/h Operations/h 9000 9000 Damp heat, constant, to IEC 60068-2-78 Damp heat, cyclical, to IEC 60068-2-30 Operations Operations Ч 106 Ч 106 10 10 IEC/EN 60947, VDE 0660, UL, CSA
  • Тип реле: Contactor
  • Coil Voltage VDC Nom: 24 В
  • Внешняя длина / высота: 68 мм
  • Внешняя ширина: 45 мм
  • External Depth: 125 мм
  • Contact Current AC Max: 12 А
  • Contact Voltage AC Max: 400 В
  • Mounting Type: DIN Rail / Panel
  • No. of Poles: 3
  • Approval Bodies: IEC/EN 60947, VDE0660, UL, CSA
  • Coil Voltage Max: 24 В DC
  • Dielectric Voltage Coil to Contact: 400 В AC
  • Dielectric Voltage Contact to Contact: 400 В AC
  • IP / NEMA Rating: 20
  • Main Contact Current AC3 Max: 12 А
  • Power Rating: 5.5kW
DILM1210(24VDC), DILM12 10(24VDC)
На английском языке: Datasheet DILM12-10(24VDC) - Moeller CONTACTOR, 5.5KW, WITH 1NO AUX
