Datasheet DILA-31(110V50HZ,120V60HZ) - Moeller Даташит Реле, WITH 3N0+1NC — Даташит
Наименование модели: DILA-31(110V50HZ,120V60HZ)
Производитель: Moeller
Описание: Реле, WITH 3N0+1NC
Type: DILA-31(110V50HZ,120V60HZ) Article No.: 276361
Ordering information
Rated operational current AC15 220 V 230 V 240 V Rated operational current AC15 380 V 400 V 415 V Conventional current, open at 60 °C Can be combined with auxiliary contact module Ie Ie Ith A A A 6 4 10 DILA-XHI(V)...
Contact sequence
Notes concerning the product group
- Тип реле: Contactor
- Coil Voltage VAC Nom: 120 В
- Contact Current Max: 6 А
- Contact Voltage AC Nom: 415 В
- Contact Configuration: 3 N/O + 1 N/C
- Coil Type: AC Coil
- Nom Operating Power: 300 мВт
- Relay Mounting: DIN Rail
- Внешняя длина / высота: 68 мм
- Внешняя ширина: 45 мм
- External Depth: 117 мм
- Contact Current AC Max: 6 А
- Contact Current DC Max: 4 А
- Contact Voltage AC Max: 415 В
- Mounting Type: DIN Rail / Panel
- No.
of Poles: 4
- Approval Bodies: IEC/EN 60947, VDE 0660, UL, CSA
- Current Rating: 6 А
- Dielectric Voltage Coil to Contact: 400 В AC
- Dielectric Voltage Contact to Contact: 400 В AC
- Frequency Max: 60Hz
- Frequency Min: 50Hz
- Input Voltage Max: 120 В AC
- Input Voltage Min: 110 В AC
- Terminal Type: Screw Terminals
DILA31(110V50HZ,120V60HZ), DILA 31(110V50HZ,120V60HZ), DILA-31(110V50HZ120V60HZ), DILA-31(110V50HZ 120V60HZ)
