Datasheet DILA-31(230V50HZ,240V60HZ) - Moeller Даташит Реле, WITH 3N0+1NC — Даташит
Moeller DILA-31(230V50HZ,240V60HZ)
Наименование модели: DILA-31(230V50HZ,240V60HZ)
DILA-31-EA(230V50HZ,240V60HZ)
Eaton Cutler Hammer
1 960 ₽
Производитель: Moeller
Описание: Реле, WITH 3N0+1NC
data sheetСкачать Data Sheet
Type: DILA-31(230V50HZ,240V60HZ) Article No.: 276364
Ordering information
Connection technique Contacts M = Make Contacts B = Break Rated operational current AC­15 220 V 230 V 240 V Rated operational current AC­15 380 V 400 V 415 V Conventional current, open at 60 °C Distinctive number and version of combination DILA(C)-31 Can be combined with auxiliary contact module Ie Ie Ith A A A Screw terminals 3M 1B 6 4 10 31E DILA-XHI(V)...
Contact sequence
Notes concerning the product group
  • Тип реле: Contactor
  • Coil Voltage VAC Nom: 240 В
  • Contact Current Max: 6 А
  • Contact Voltage AC Nom: 415 В
  • Contact Configuration: 3 N/O + 1 N/C
  • Coil Type: AC Coil
  • Nom Operating Power: 300 мВт
  • Relay Mounting: DIN Rail
  • Внешняя длина / высота: 68 мм
  • Внешняя ширина: 45 мм
  • External Depth: 117 мм
  • Contact Current AC Max: 6 А
  • Contact Current DC Max: 4 А
  • Contact Voltage AC Max: 415 В
  • Mounting Type: DIN Rail / Panel
  • No.
    of Poles: 4
  • Approval Bodies: IEC/EN 60947, VDE 0660, UL, CSA
  • Current Rating: 6 А
  • Dielectric Voltage Coil to Contact: 400 В AC
  • Dielectric Voltage Contact to Contact: 400 В AC
  • Frequency Max: 60Hz
  • Frequency Min: 50Hz
  • IP / NEMA Rating: IP20
  • Input Voltage Max: 240 В AC
  • Input Voltage Min: 230 В AC
  • Terminal Type: Screw Terminals
DILA31(230V50HZ,240V60HZ), DILA 31(230V50HZ,240V60HZ), DILA-31(230V50HZ240V60HZ), DILA-31(230V50HZ 240V60HZ)
На английском языке: Datasheet DILA-31(230V50HZ,240V60HZ) - Moeller RELAY, WITH 3N0+1NC
