Datasheet AGN200S12 - Panasonic Даташит Реле, DPDT 12 В DC — Даташит
Panasonic AGN200S12
Наименование модели: AGN200S12
37 предложений от 15 поставщиков
Промышленные/Универсальные Реле, Electromechanical Relay 12VDC 1.028KΩ 1A DPDT(10.6x5.7x10)mm SMD General Purpose Relay
AGN200S12Z
Panasonic
205 ₽
AGN200S12Z
Panasonic
255 ₽
Эиком
AGN200S12
Panasonic
от 299 ₽
AGN200S12J
Panasonic
от 444 ₽
Производитель: Panasonic
Описание: Реле, DPDT 12 В DC
data sheetСкачать Data Sheet
GN (AGN)
ULTRA-SMALL PACKAGE SLIM POLARIZED RELAY
TESTING
GN RELAYS (AGN)
· Increased packaging density Due to highly efficient magnetic circuit design, leakage flux is reduced and changes in electrical characteristics from components being mounted closetogether are minimized.
This all means a packaging density higher than ever before. · Nominal operating power: 140 mW · Outstanding vibration and shock resistance. Functional shock resistance: 750 m/s2 {75G} Destructive shock resistance: 1,000 m/s2 {100G} Functional vibration resistance: 10 to 55 Hz (at double amplitude of 3.3 mm .130 inch) Destructive vibration resistance: 10 to 55 Hz (at double amplitude of 5 mm .197 inch)
  • Тип реле: General Purpose
  • Coil Voltage VDC Nom: 12 В
  • Contact Current Max: 1 А
  • Contact Voltage AC Nom: 125 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 1.028 кОм
  • Contact Configuration: DPDT
  • Coil Type: DC Coil, Monostable
  • Coil Current: 11.7 мА
  • Nom Operating Power: 140 мВт
  • Relay Mounting: PC Board
  • Внешняя длина / высота: 9 мм
  • Внешняя ширина: 10.6 мм
  • External Depth: 5.7 мм
  • Contact Current AC Max: 300 мА
  • Contact Current DC Max: 1 А
  • Contact Voltage AC Max: 125 В
  • Contact Voltage DC Max: 30 В
  • Mounting Type: SMT
  • No. of Poles: 2
  • Operating Temperature Max: 85°C
  • Series: AGN
  • Temperature Operating Min: -40°C
  • Termination Type: SMD
  • Type: Single Side Stable
  • Contact Resistance: 100 MOhm
  • DC Coil Power: 140 мВт
  • Insulation Resistance: 1000 MOhm
  • Insulation Resistance Voltage: 500 В DC
  • Operating Time: 4 мс
  • Release Time: 4 мс
  • Switch Current Max: 1 А
  • Switch Power Max: 30 Вт
  • Switching Power Max: 37.5VA
  • Terminal Type: S Type
Дополнительные аксессуары:
  • Tyco - 1-1814655-1
  • Xytronic - 226
На английском языке: Datasheet AGN200S12 - Panasonic RELAY, DPDT 12 V DC
