Datasheet AGQ200A24 - Panasonic Даташит Реле, DPDT, 24 В DC — Даташит
Panasonic AGQ200A24
Наименование модели: AGQ200A24
39 предложений от 17 поставщиков
Промышленные/Универсальные Реле, Signal Relay 24VDC 2A DPDT( (10.6mm 8.4mm 5.4mm)) SMD
Элитан
AGQ200A24
Matsushita
191 ₽
Зенер
Россия и страны ТС
AGQ200A24X
от 312 ₽
AGQ200A24
Panasonic
от 403 ₽
TradeElectronics
AGQ200A24Z
Panasonic
Производитель: Panasonic
Описание: Реле, DPDT, 24 В DC
data sheetСкачать Data Sheet
GQ (AGQ)
ULTRA-SMALL PACKAGE FLAT POLARIZED RELAY
TESTING
GQ RELAYS (AGQ)
· Increased packaging density Due to highly efficient magnetic circuit design, leakage flux is reduced and changes in electrical characteristics from components being mounted closetogether are minimized.
This all means a packaging density higher than ever before. · Nominal operating power: 140 mW · Outstanding vibration and shock resistance. Functional shock resistance: 750 m/s2 {75G} Destructive shock resistance: 1,000 m/s2 {100G} Functional vibration resistance: 10 to 55 Hz (at double amplitude of 3.3 mm .130 inch) Destructive vibration resistance: 10 to 55 Hz (at double amplitude of 5 mm .197 inch)
  • Тип реле: General Purpose
  • Coil Voltage VDC Nom: 24 В
  • Contact Current Max: 1 А
  • Contact Voltage AC Nom: 125 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 2.504 кОм
  • Contact Configuration: DPDT
  • Coil Type: DC Coil, Monostable
  • Coil Current: 9.6 мА
  • Nom Operating Power: 230 мВт
  • Relay Mounting: PC Board
  • Внешняя длина / высота: 5.4 мм
  • Внешняя ширина: 10.6 мм
  • External Depth: 7.2 мм
  • Contact Current AC Max: 1 А
  • Contact Current DC Max: 1 А
  • Contact Voltage AC Max: 125 В
  • Contact Voltage DC Max: 30 В
  • Mounting Type: SMT
  • No. of Poles: 2
  • Operating Temperature Max: 85°C
  • Series: AGQ
  • Temperature Operating Min: -40°C
  • Termination Type: SMD
  • Type: Single Side Stable
  • Contact Resistance: 100 MOhm
  • DC Coil Power: 230 мВт
  • Insulation Resistance: 1000 MOhm
  • Insulation Resistance Voltage: 500 В DC
  • Operating Time: 4 мс
  • Release Time: 4 мс
  • Switch Current Max: 1 А
  • Switch Power Max: 30 Вт
  • Switching Power Max: 37.5VA
  • Terminal Type: A Type
Дополнительные аксессуары:
  • Tyco - 1-1814655-1
  • Xytronic - 226
На английском языке: Datasheet AGQ200A24 - Panasonic RELAY, DPDT, 24 V DC
