Источники питания Keen Side
Datasheet AGQ200A4H - Panasonic Даташит Реле, PCB, DPCO, 4.5 В DC — Даташит
Panasonic AGQ200A4H
Наименование модели: AGQ200A4H
26 предложений от 14 поставщиков
Промышленные/Универсальные Реле, Signal Relay 4.5VDC 2A DPDT( (10.6mm 8.4mm 5.4mm)) SMD
AGQ200A4H
Panasonic
50 ₽
727GS
AGQ200A4H
Panasonic
AGQ200A4H
Panasonic
AGQ200A4H-Z
Panasonic
Производитель: Panasonic
Описание: Реле, PCB, DPCO, 4.5 В DC
data sheetСкачать Data Sheet
GQ
TESTING
ULTRA-SMALL PACKAGE FLAT POLARIZED RELAY
GQ-RELAYS
Due to highly efficient magnetic circuit design, leakage flux is reduced and changes in electrical characteristics from components being mounted close-together are minimized.
This all means a packaging density higher than ever before. · Nominal operating power: 140 mW · Outstanding vibration and shock resistance. Functional shock resistance: 750 m/s2 {75G} Destructive shock resistance: 1,000 m/s2 {100G} Functional vibration resistance: 10 to 55 Hz (at double amplitude of 3.3 mm .130 inch) Destructive vibration resistance: 10 to 55 Hz (at double amplitude of 5 mm .197 inch)
  • Тип реле: General Purpose
  • Coil Voltage VDC Nom: 4.5 В
  • Contact Current Max: 1 А
  • Contact Voltage AC Nom: 125 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 145 Ом
  • Contact Configuration: DPCO
  • Coil Type: DC Coil, Monostable
  • Coil Current: 31 мА
  • Nom Operating Power: 140 мВт
  • Relay Mounting: PC Board
  • Внешняя длина / высота: 10.6 мм
  • Внешняя ширина: 7.2 мм
  • External Depth: 5.2 мм
  • Contact Current AC Max: 300 мА
  • Contact Current DC Max: 1 А
  • Contact Voltage AC Max: 125 В
  • Contact Voltage DC Max: 30 В
  • Mounting Type: SMT
  • No. of Poles: 2
  • Operating Temperature Max: 85°C
  • Series: GQ
  • Temperature Operating Min: -40°C
  • Contact Material: Silver Palladium, Gold clad
  • DC Coil Power: 140 мВт
  • Operating Time: 4 мс
  • Release Time: 4 мс
  • Switch Current Max: 1 А
На английском языке: Datasheet AGQ200A4H - Panasonic RELAY, PCB, DPCO, 4.5 V DC
