Datasheet ALD124 - Panasonic Даташит Реле, PCB, SPNO, 24 В DC — Даташит
Наименование модели: ALD124
![]() 15 предложений от 15 поставщиков Реле Мощности, Electromechanical Relay SPST-NO 3A 24VDC 2.88KΩ Through Hole | |||
ALD124W Panasonic | 31 ₽ | ||
ALD124 Panasonic | 114 ₽ | ||
ALD124 Matsushita | 1 301 ₽ | ||
ALD124W Panasonic | по запросу |
Производитель: Panasonic
Описание: Реле, PCB, SPNO, 24 В DC
1 Form A Slim Power Relay
LD-RELAYS
4.
High shock resistance The relay withstands a functional shock resistance of 300m/s2 [approx. 30 G more] 5. High insulation resistance · Creepage distance and clearances between contact and coil: Min. 6 mm .236 inch (In compliance with IEC65) · Surge withstand voltage between contact and coil: 10,000 V or more.
UL File No.: E43028 CSA File No.: LR26550
Max. 20.5 .807 Max. 7.2 .284 Max. 15.3 .602
- Тип реле: Power
- Coil Voltage VDC Nom: 24 В
- Contact Current Max: 3 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 2.88 кОм
- Contact Configuration: SPNO
- Coil Type: DC Coil
- Coil Current: 8.3 мА
- Nom Operating Power: 200 мВт
- Relay Mounting: PC Board
- Внешняя длина / высота: 15.3 мм
- Внешняя ширина: 20.5 мм
- External Depth: 7.2 мм
- Contact Current AC Max: 3 А
- Contact Current DC Max: 3 А
- Contact Voltage AC Max: 277 В
- Contact Voltage DC Max: 30 В
- Mounting Type: PCB
- No. of Poles: 1
- Operating Temperature Max: +70°C
- Series: LD
- Temperature Operating Min: -40°C
- Approval Bodies: UL, CSA, VDE
- Contact Material: Silver alloy
- DC Coil Power: 200 мВт
- Switch Current Max: 3 А
- Switching Power Max: 90 Вт
