Datasheet A30-30-10-24V-50HZ - ABB Даташит CONTACTOR, 15KW, 32 А — Даташит
Наименование модели: A30-30-10-24V-50HZ
SCA CONNECTOR IDC TYPE(MALE) | |||
| A30-30-10-24V-50HZ DB Lectro | по запросу | ||
Производитель: ABB
Описание: CONTACTOR, 15KW, 32 А
Control Gear
Contents
3 Pole Contactors..........................................................................
4 Pole Contactors.......................................................................... Mini Contactors.............................................................................. Manual Motor Starters .................................................................. Field Bus Plugs.............................................................................. Softstarters.................................................................................... Pilot Devices.................................................................................. Switching Power Supplies (CP Range) ..........................................
2-2 2-20 2-37 2-42 2-49 2-54 2-58 2-72
Return to main index
- Тип реле: Contactor
- Coil Voltage VAC Nom: 24 В
- Contact Configuration: SPNO
- Внешняя длина / высота: 90 мм
- Внешняя ширина: 54 мм
- External Depth: 108.3 мм
- SVHC: No SVHC (18-Jun-2010)
- Contact Current AC Max: 32 А
- Contact Voltage AC Max: 400 В
- Mounting Type: Panel
- No. of Poles: 3
- Approval Bodies: UL, CSA
- Coil Operating Voltage: 24 В
- Contact Current Max: 32 А
- Frame Size: A30
- IP / NEMA Rating: 20
- Main Contact Current AC1 Max: 55 А
- Main Contact Current AC3 Max: 32 А
- Power Rating: 15kW
A30301024V50HZ, A30 30 10 24V 50HZ
