Datasheet A110-30-11-230V-50HZ - ABB Даташит CONTACTOR, 55KW, 110 А — Даташит
Наименование модели: A110-30-11-230V-50HZ
![]() 8 предложений от 8 поставщиков Выключатели, ABB A110-30-11-81 Contactor, 24VAC Coil, 110A at 3-Phase, 140A at 1-Phase | |||
A110-30-11-81 ABB | 22 576 ₽ | ||
A110-30-11-51 ABB | 23 722 ₽ | ||
A110-30-11-51-ABBG | 133 446 ₽ | ||
A110-30-11-84 | по запросу |
Производитель: ABB
Описание: CONTACTOR, 55KW, 110 А
Control Gear
Contents
3 Pole Contactors..........................................................................
4 Pole Contactors.......................................................................... Mini Contactors.............................................................................. Manual Motor Starters .................................................................. Field Bus Plugs.............................................................................. Softstarters.................................................................................... Pilot Devices.................................................................................. Switching Power Supplies (CP Range) ..........................................
2-2 2-20 2-37 2-42 2-49 2-54 2-58 2-72
Return to main index
- Тип реле: Contactor
- Coil Voltage VAC Nom: 230 В
- Contact Configuration: DPCO
- Внешняя длина / высота: 148 мм
- Внешняя ширина: 102 мм
- External Depth: 123.5 мм
- SVHC: No SVHC (18-Jun-2010)
- Contact Current AC Max: 110 А
- Contact Voltage AC Max: 400 В
- Mounting Type: Panel
- No. of Poles: 3
- Approval Bodies: UL, CSA
- Coil Operating Voltage: 240 В
- Contact Current Max: 110 А
- Frame Size: A110
- IP / NEMA Rating: 20
- Main Contact Current AC1 Max: 160 А
- Main Contact Current AC3 Max: 110 А
- Power Rating: 55kW
A1103011230V50HZ, A110 30 11 230V 50HZ
