Datasheet A16-30-10-110V-50HZ - ABB Даташит CONTACTOR, 7.5KW, 17 А — Даташит
Наименование модели: A16-30-10-110V-50HZ
![]() 5 предложений от 5 поставщиков Промышленные/Универсальные Реле, ABB A16-30-10-110V-50Hz Contactor, 690VAC, 3Pole, 3PST-NO, Panel, 30A, 110V | |||
A16-30-10-110V-50HZ ABB | 5 152 ₽ | ||
A16-30-10-110V-50HZ ABB | 7 358 ₽ | ||
A16-30-10-110V-50HZ ABB | 27 032 ₽ | ||
A16-30-10-110V-50HZ DB Lectro | по запросу |
Производитель: ABB
Описание: CONTACTOR, 7.5KW, 17 А
Control Gear
Contents
3 Pole Contactors..........................................................................
4 Pole Contactors.......................................................................... Mini Contactors.............................................................................. Manual Motor Starters .................................................................. Field Bus Plugs.............................................................................. Softstarters.................................................................................... Pilot Devices.................................................................................. Switching Power Supplies (CP Range) ..........................................
2-2 2-20 2-37 2-42 2-49 2-54 2-58 2-72
Return to main index
- Тип реле: Contactor
- Coil Voltage VAC Nom: 110 В
- Contact Current Max: 17 А
- Contact Voltage AC Nom: 400 В
- Contact Configuration: SPNO
- Coil Type: AC
- Relay Mounting: Panel
- Внешняя длина / высота: 74 мм
- Внешняя ширина: 44 мм
- External Depth: 74 мм
- SVHC: No SVHC (18-Jun-2010)
- Contact Current AC Max: 17 А
- Contact Voltage AC Max: 400 В
- Mounting Type: Panel
- No. of Poles: 3
- Approval Bodies: UL, CSA
- Coil Operating Voltage: 110 В
- Frame Size: A16
- IP / NEMA Rating: 20
- Main Contact Current AC1 Max: 30 А
- Main Contact Current AC3 Max: 17 А
- Power Rating: 7.5kW
A163010110V50HZ, A16 30 10 110V 50HZ
