Datasheet 60.43.9.012.0000 - Finder Даташит Реле, PCB, 3PCO, 12 В DC — Даташит
Finder 60.43.9.012.0000
Наименование модели: 60.43.9.012.0000
Реле Мощности, RELAY, PCB, 3PCO, 12VDC; Series: 60; Relay Type: General Purpose; Voltage, Coil DC Nom: 12V; Coil Resistance: 110Ω;...
Finder
1 102 ₽
Finder
1 157 ₽
Finder
1 285 ₽
Производитель: Finder
Описание: Реле, PCB, 3PCO, 12 В DC
data sheetСкачать Data Sheet
60 Series - General purpose relays 6 - 10 A Features
Plug-in mount 10 A General purpose relay & 3 pole changeover contacts Cadmium Free contacts (preferred version) · AC coils & DC coils · UL Listed (certain relay/socket combinations) · Contact material options · Lockable test button with mechanical flag indicator (preferred version) · 90 series sockets, coil EMC suppression and timer accessories
· ·2
60.12
60.13
  • Тип реле: General Purpose
  • Coil Voltage VDC Nom: 12 В
  • Contact Current Max: 20 А
  • Contact Voltage AC Nom: 250 В
  • Coil Resistance: 110 Ом
  • Contact Configuration: 3PCO
  • Coil Type: DC Coil
  • Coil Current: 109 мА
  • Nom Operating Power: 1.3 Вт
  • Relay Mounting: PC Board
  • Внешняя длина / высота: 36 мм
  • Внешняя ширина: 32.2 мм
  • External Depth: 43 мм
  • Contact Current AC Max: 10 А
  • Contact Current DC Max: 10 А
  • Contact Voltage AC Max: 250 В
  • Contact Voltage DC Max: 30 В
  • Mounting Type: PCB
  • No.
    of Poles: 3
  • Operating Temperature Max: 70°C
  • Series: 60
  • Temperature Operating Min: -40°C
  • AC Coil Power: 2.2VA
  • Approval Bodies: BSI, VDE, CSA, SEV, IMQ, UL, DEMKO, RINA, BEAB
  • Coil Operating Lower Percent Limit: 80%
  • Coil Operating Upper Percent Limit: 110%
  • Contact Material: Silver Nickel
  • DC Coil Power: 1.3 Вт
  • Dielectric Strength VDC: 2000 В
  • Operating Time: 20 мс
  • PCB Hole Diameter: 1.5 мм
  • Release Time: 20 мс
  • Switch Current Max: 10 А
  • Switched Current Max: 20 А
  • Switching Power Max: 2500VA
  • Switching Voltage AC / DC Min: 380 В AC
На английском языке: Datasheet 60.43.9.012.0000 - Finder RELAY, PCB, 3PCO, 12 V DC
