Datasheet 60.12.8.012.0040 - Finder Даташит Реле, DCPO, 10 А, 12VAC — Даташит
Наименование модели: 60.12.8.012.0040
|  Купить 60.12.8.012.0040 на РадиоЛоцман.Цены — от 1 023 до 4 406 ₽ 14 предложений от 8 поставщиков Реле Мощности, Ind. Plug-In Relay, 4PDT 7A, 120V AC coil, AgNi contact, lockable test button & LED | |||
| 60.12.8.012.0040 Finder | 1 240 ₽ | ||
| 60.12.8.012.0040 Finder | от 2 908 ₽ | ||
| 60.12.8.012.0040 Finder | от 4 406 ₽ | ||
| 60.12.8.012.0040 | по запросу | ||
Производитель: Finder
Описание: Реле, DCPO, 10 А, 12VAC
60 Series - General purpose relays 6 - 10 A Features
Plug-in mount 10 A General purpose relay & 3 pole changeover contacts Cadmium Free contacts (preferred version) · AC coils & DC coils · UL Listed (certain relay/socket combinations) · Contact material options · Lockable test button with mechanical flag indicator (preferred version) · 90 series sockets, coil EMC suppression and timer accessories
· ·2
60.12
60.13
- Тип реле: General Purpose
- Coil Voltage VAC Nom: 12 В
- Contact Current Max: 20 А
- Contact Voltage AC Nom: 250 В
- Coil Resistance: 19 Ом
- Contact Configuration: DPCO
- Coil Type: AC Coil
- Coil Current: 183 мА
- Nom Operating Power: 2.2VA
- Relay Mounting: Plug-In
- Внешняя длина / высота: 51 мм
- Внешняя ширина: 32.5 мм
- External Depth: 36.2 мм
- Contact Current AC Max: 10 А
- Contact Current DC Max: 10 А
- Contact Voltage AC Max: 250 В
- Contact Voltage DC Max: 30 В
- Mounting Type: Plug-In
- No.of Poles: 2
- Operating Temperature Max: 70°C
- Series: 60
- Temperature Operating Min: -40°C
- AC Coil Power: 2.2VA
- Approval Bodies: BSI, VDE, CSA, RINA, UL, BEAB, IMQ, SETI, SEMKO, DEMKO
- Coil Operating Lower Percent Limit: 80%
- Coil Operating Upper Percent Limit: 110%
- Contact Material: Silver Nickel
- Dielectric Strength VDC: 2000 В
- Operating Time: 9 мс
- Release Time: 9 мс
- Switch Current Max: 20 А
- Switched Current Max: 20 А
- Switched Voltage Max: 400 В
- Switching Power Max: 2500VA
- Switching Voltage AC / DC Min: 400 В AC
 Скачать Data Sheet
Скачать Data Sheet
