Datasheet 44.62.7.012.4000 - Finder Даташит Реле, PCB, DPCO, 12 В DC — Даташит
Finder 44.62.7.012.4000
Наименование модели: 44.62.7.012.4000
Реле Мощности, FINDER 44.62.7.012.4000 Power Relay, DPDT, 12VDC, 10A, 44 Series, Through Hole
Finder
415 ₽
Finder
415 ₽
Finder
679 ₽
Производитель: Finder
Описание: Реле, PCB, DPCO, 12 В DC
data sheetСкачать Data Sheet
44 Series - Miniature PCB relays 6 - 10 A Features
2 Pole relay range 44.52 - 2 Pole 6 A (5 mm pin pitch) 44.62 - 2 Pole 10 A (5 mm pin pitch) PCB mount - direct or via PCB socket 35 mm rail mount - via screw and screwless sockets High physical separation between adjacent contacts · DC coils (Standard or sensitive) · Cadmium Free contact materials · 8 mm, 6 kV (1.2/50 µs) isolation, coil-contacts · UL Listing (certain relay/socket combinations) · Flux proof: RT II · 95 series sockets · Coil EMC suppression · Timer accessories 86 series
44.52
44.62
  • Тип реле: Miniature
  • Coil Voltage VDC Nom: 12 В
  • Contact Current Max: 20 А
  • Contact Voltage AC Nom: 250 В
  • Coil Resistance: 300 Ом
  • Contact Configuration: DPCO
  • Coil Type: DC Coil, Sensitive
  • Coil Current: 40 мА
  • Nom Operating Power: 500 мВт
  • Relay Mounting: PC Board
  • Внешняя длина / высота: 29 мм
  • Внешняя ширина: 12.4 мм
  • External Depth: 25 мм
  • Contact Current AC Max: 10 А
  • Contact Current DC Max: 10 А
  • Contact Voltage AC Max: 240 В
  • Contact Voltage DC Max: 30 В
  • Mounting Type: PCB
  • No.
    of Poles: 2
  • Operating Temperature Max: 70°C
  • Series: 44
  • Temperature Operating Min: -20°C
  • Approval Bodies: VDE, UL, CSA, IMQ
  • Approval Category: VDE, UL, CSA, IMQ
  • Coil Operating Lower Percent Limit: 80%
  • Coil Operating Upper Percent Limit: 150%
  • Contact Material: Silver Nickel
  • DC Coil Power: 500 мВт
  • Operating Time: 10 мс
  • PCB Hole Diameter: 1.5 мм
  • Release Time: 7 мс
  • Switch Current Max: 10 А
Дополнительные аксессуары:
  • Finder - 95.15.2SMA
  • Finder - 95.45SMA
На английском языке: Datasheet 44.62.7.012.4000 - Finder RELAY, PCB, DPCO, 12 V DC
