Datasheet 41.31.9.006.0010 - Finder Даташит Реле, PCB, SPCO, 6 В DC — Даташит
Наименование модели: 41.31.9.006.0010
Купить 41.31.9.006.0010 на РадиоЛоцман.Цены — от 304 до 403 ₽ Реле Мощности, RELAY, PCB, SPCO, 6VDC; Series: 41; Relay Type: General Purpose; Voltage, Coil DC Nom: 6V; Coil Resistance: 90Ω; No...... | |||
| 41.31.9.006.0010 Finder | 304 ₽ | ||
| 41.31.9.006.0010 Finder | 310 ₽ | ||
| 413190060010 Finder | 403 ₽ | ||
Производитель: Finder
Описание: Реле, PCB, SPCO, 6 В DC
41 Series - Low profile PCB relays 8 - 12 - 16 A Features
1 & 2 Pole - Low profile (15.7 mm height) 41.31 - 1 Pole 12 A (3.5 mm pin pitch) 41.52 - 2 Pole 8 A (5 mm pin pitch) 41.61 - 1 Pole 16 A (5 mm pin pitch) PCB mount - direct or via PCB socket
· DC ·8
41.31
41.52
- Тип реле: General Purpose
- Coil Voltage VDC Nom: 6 В
- Contact Current Max: 25 А
- Contact Voltage AC Nom: 250 В
- Coil Resistance: 90 Ом
- Contact Configuration: SPCO
- Coil Type: DC Coil
- Coil Current: 6.6 мА
- Nom Operating Power: 400 мВт
- Relay Mounting: PC Board
- Внешняя длина / высота: 15.7 мм
- Внешняя ширина: 12.7 мм
- External Depth: 29 мм
- Contact Current AC Max: 12 А
- Contact Current DC Max: 12 А
- Contact Voltage AC Max: 250 В
- Mounting Type: PCB
- No.
of Poles: 1
- Operating Temperature Max: 85°C
- Series: 41
- Temperature Operating Min: -40°C
- Approval Bodies: UL, CSA, VDE
- Coil Operating Lower Percent Limit: 255%
- Coil Operating Upper Percent Limit: 70%
- Contact Material: AgNi
- Contact Resistance: 90 Ом
- DC Coil Power: 400 мВт
- Operating Time: 5 мс
- Release Time: 4 мс
- Switch Current Max: 25 А
- Switching Voltage Max: 400 В AC
