Линейка продуктов KEEN SIDE
Datasheet 3RH11311BB40 - Siemens Даташит CONTACTOR, 3NO+1NC — Даташит
Siemens 3RH11311BB40
Наименование модели: 3RH11311BB40
, Contactor:4Pole; 24VDC; 6A; NC + NO x3; DIN, on panel; Size: S00
3RH1131-1BB40
2 921 ₽
3RH1131-1BB40
2 921 ₽
3RH1131-1BB40
3 338 ₽
3RH1131-1BB40
Yageo
АЦП азиатских производителей
Производитель: Siemens
Описание: CONTACTOR, 3NO+1NC
data sheetСкачать Data Sheet
3RT, 3RH, 3TB, 3TC, 3TH, 3TK Contactors for Special Applications
Contactors with Extended Tolerance 0.7 ...
1.25 x Us , for Railway Applications
3RT10 motor contactors, 5.5 ... 45 kW
DC operation · DC solenoid system Screw terminals For screw and snap-on mounting onto standard mounting rail Contactor control unit Solenoid fitted with varistor
Rated data AC-2 and AC-3 Tu: up to 70 °C Rated operational current Ie at 400 V A Auxiliary contacts1) Rated control DT supply voltage Us Screw terminals PU PS* (UNIT, SET, M) Price per PU PG Weight per PU approx.
  • Тип реле: Contactor
  • Coil Voltage VDC Nom: 24 В
  • Contact Configuration: 3 N/O + 1 N/C
  • Coil Type: DC
  • Relay Mounting: DIN Rail
  • Внешняя длина / высота: 57.5 мм
  • Внешняя ширина: 45 мм
  • External Depth: 106 мм
  • Contact Current AC Max: 6 А
  • Contact Voltage AC Max: 230 В
  • Mounting Type: DIN Rail
  • No. of Poles: 4
  • Operating Temperature Max: 60°C
  • Series: 3RH11
  • Temperature Operating Min: -25°C
  • Approval Bodies: UL, CSA
  • Dielectric Strength VAC: 600 В AC
  • IP / NEMA Rating: 20
  • Main Contact Current AC3 Max: 10 А
  • Switch Current Max: 10 А
На английском языке: Datasheet 3RH11311BB40 - Siemens CONTACTOR, 3NO+1NC
