Datasheet 3RT10162JB42 - Siemens Даташит Реле, COUPLING — Даташит
Наименование модели: 3RT10162JB42
Реле, модуль Ввода/Вывода, Sirius 3RT1 3Pole Contactor, 9A, 24VDC Coil | |||
| 3RT10162JB42 | 14 932 ₽ | ||
Производитель: Siemens
Описание: Реле, COUPLING
3RT, 3RH, 3TB, 3TC, 3TH, 3TK Contactors for Special Applications
Contactors with Extended Tolerance 0.7 ...
1.25 x Us , for Railway Applications
3RT10 motor contactors, 5.5 ... 45 kW
DC operation · DC solenoid system Screw terminals For screw and snap-on mounting onto standard mounting rail Contactor control unit Solenoid fitted with varistor
Rated data AC-2 and AC-3 Tu: up to 70 °C Rated operational current Ie at 400 V A Auxiliary contacts1) Rated control DT supply voltage Us Screw terminals PU PS* (UNIT, SET, M) Price per PU PG Weight per PU approx.
- Тип реле: Contactor
- Coil Voltage VDC Nom: 24 В
- Contact Configuration: SPNC
- Внешняя длина / высота: 57.5 мм
- Внешняя ширина: 45 мм
- External Depth: 99 мм
- Contact Current AC Max: 9 А
- Contact Voltage AC Max: 400 В
- Mounting Type: DIN Rail / Panel
- No. of Poles: 3
- Series: 3RT10
- Approval Bodies: UL, CSA
- Main Contact Current AC3 Max: 9 А
- Switch Current Max: 9 А
- Switch Power Max: 4kW
Купить 3RT10162JB42 на РадиоЛоцман.Цены
