Datasheet 3RT10263BB40 - Siemens Даташит CONTACTOR, AC-3, 11KW/400 В — Даташит
Наименование модели: 3RT10263BB40
Купить 3RT10263BB40 на РадиоЛоцман.Цены — от 6 892 до 7 844 ₽ , Contactor:3Pole; 24VDC; 25A; NO x3; DIN, on panel; Series:3RT10 | |||
| 3RT1026-3BB40 | 6 892 ₽ | ||
| 3RT1026-3BB40 | 7 844 ₽ | ||
Производитель: Siemens
Описание: CONTACTOR, AC-3, 11KW/400 В
Controls Contactors and Contactor Assemblies
3
3RH, 3TH Contactor Relays 3RH1 contactor relays, 4- and 8-pole 3RH14 latched contactor relays, 4-pole 3TH4 contactor relays, 8- and 10-pole 3TH2 contactor relays, 4- and 8-pole 3RH11 coupling relays for switching auxiliary circuits, 4-pole 3RT Coupling Relays 3RT10 coupling relays (interface), for switching motors, 3-pole, 3 ...
11 kW 3TX7, 3RS18 Coupling Relays 3TX7 Coupling Relays, Narrow Design Relay couplers Relay couplers with plug-in design Semiconductor couplers 3RS18 Coupling Relays with Industrial Housing Relay couplers LZX Plug-in Relays Relay couplers 3TG10 Power Relays/Miniature Contactors 4-pole, 4 kW Accessories and Spare Parts for 3RT, 3RH Contactors and Contactor Relays Accessories for 3RT, 3RH contactors and contactor relays Spare parts for 3RT, 3RH contactors and contactor relays for 3T Contactors and Contactor Relays Accessories for 3TB, 3TC, 3TF, 3TG, 3TK contactors Accessories for 3TH contactor relays Spare parts fo
- Тип реле: Contactor
- Coil Voltage VDC Nom: 24 В
- Внешняя длина / высота: 60 мм
- Внешняя ширина: 45 мм
- External Depth: 109 мм
- Contact Current AC Max: 25 А
- Contact Voltage AC Max: 400 В
- Mounting Type: DIN Rail / Panel
- No. of Poles: 3
- Operating Temperature Max: 60°C
- Series: 3RT10
- Temperature Operating Min: -25°C
- AC Coil Power: 3.3 Вт
- Approval Bodies: CSA, UL
- Contact Current Max: 25 А
- Contact Voltage AC Nom: 230 В AC
- DC Coil Power: 26.5VA
- IP / NEMA Rating: 20
- Main Contact Current AC3 Max: 25 А
- Mechanical Life: 300,000,000 Operations
- No. of Mechanical Operations: 300000000
- Switch Current Max: 25 А
- Switch Power Max: 11kW
- Switching Voltage Max: 690 В
