Datasheet IRGB14C40LPBF - International Rectifier Даташит IGBT, 430 В, 20 А, TO-220 — Даташит
International Rectifier IRGB14C40LPBF
Наименование модели: IRGB14C40LPBF
14 предложений от 14 поставщиков
Транзистор IGBT, Trans IGBT Chip N-CH 370V 20A 125000mW 3Pin(3+Tab) TO-220AB Tube
IRGB14C40LPBF
Infineon
141 ₽
IRGB14C40LPBF
222 ₽
IRGB14C40LPBF
IRGB14C40LPBF
Infineon
Описание: IGBT, 430 В, 20 А, TO-220
data sheetСкачать Data Sheet
PD - 95193
Ignition IGBT
Features Most Rugged in Industry Logic-Level Gate Drive > 6KV ESD Gate Protection Low Saturation Voltage High Self-clamped Inductive Switching Energy TO-220 is available in PbF as a Lead-Free
The advanced IGBT process family includes a MOS gated, N-channel logic level device which is intended for coil-on-plug automotive ignition applications and small-engine ignition circuits.
Unique features include on-chip active voltage clamps between the Gate-Emitter and Gate-Collector which provide over voltage protection capability in ignition circuits.
Absolute Maximum Ratings
  • Тип транзистора: IGBT
  • DC Collector Current: 20 А
  • Collector Emitter Voltage Vces: 1.75 В
  • Power Dissipation Max: 125 Вт
  • Collector Emitter Voltage V(br)ceo: 430 В
  • Корпус транзистора: TO-220
  • Количество выводов: 3
  • Clamping Voltage: 430 В
  • Current Ic Continuous a Max: 20 А
  • Current Temperature: 25°C
  • Device Marking: IRGB14C40LPbF
  • Fall Time Max: 2.8 нс
  • Junction Temperature Tj Max: 175°C
  • Junction Temperature Tj Min: -40°C
  • Количество транзисторов: 1
  • Package / Case: TO-220
  • Power Dissipation: 125 Вт
  • Power Dissipation Pd: 125 Вт
  • Rise Time: 2400 нс
  • Termination Type: Through Hole
  • Voltage Vces: 430 В
Дополнительные аксессуары:
  • Fischer Elektronik - WLK 5
На английском языке: Datasheet IRGB14C40LPBF - International Rectifier IGBT, 430 V, 20 A, TO-220
