Оптопары и оптореле Megawin
Datasheet HGTG30N60B3 - Fairchild Даташит TRANSISTOR, IGBT — Даташит
Fairchild HGTG30N60B3
Наименование модели: HGTG30N60B3
32 предложений от 27 поставщиков
Дискретные полупроводники Транзисторы — биполярные с изолированным затвором (IGBT) — одиночные
HGTG30N60B3D
69 ₽
HGTG30N60B3D
139 ₽
HGTG30N60B3D_Q
HGTG30N60B3D
Murata
Производитель: Fairchild
Описание: TRANSISTOR, IGBT
data sheetСкачать Data Sheet
HGTG30N60B3
Data Sheet November 2004
60A, 600V, UFS Series N-Channel IGBT
The HGTG30N60B3 is a MOS gated high voltage switching device combining the best features of MOSFETs and bipolar transistors.
This device has the high input impedance of a MOSFET and the low on-state conduction loss of a bipolar transistor. The much lower on-state voltage drop varies only moderately between 25oC and 150oC. The IGBT is ideal for many high voltage switching applications operating at moderate frequencies where low conduction losses are essential, such as: AC and DC motor controls, power supplies and drivers for solenoids, relays and contactors. Formerly Developmental Type TA49170.
Features
  • Тип транзистора: IGBT
  • DC Collector Current: 60 А
  • Collector Emitter Voltage Vces: 1.45 В
  • Power Dissipation Max: 208 Вт
  • Collector Emitter Voltage V(br)ceo: 600 В
  • Operating Temperature Range: -55°C to +150°C
  • Корпус транзистора: TO-247
  • Количество выводов: 3
  • Current Ic Continuous a Max: 60 А
  • Package / Case: TO-247
  • Power Dissipation: 208 Вт
  • Termination Type: Through Hole
  • Полярность транзистора: NPN
  • Voltage Vces: 1.45 В
Дополнительные аксессуары:
  • Fischer Elektronik - WLK 5
На английском языке: Datasheet HGTG30N60B3 - Fairchild TRANSISTOR, IGBT
