Datasheet HGTG30N60B3D. - Fairchild Даташит IGBT,N CH,600V,30A,TO-247 — Даташит
Наименование модели: HGTG30N60B3D.
![]() 33 предложений от 22 поставщиков Биполярные транзисторы с изолированным затвором (IGBT) 600V N-Channel IGBT UFS Series | |||
HGTG30N60B3D ON Semiconductor | 67 ₽ | ||
HGTG30N60B3D | от 455 ₽ | ||
HGTG30N60B3D ON Semiconductor | от 1 340 ₽ | ||
HGTG30N60B3D ON Semiconductor | по запросу |
Производитель: Fairchild
Описание: IGBT,N CH,600V,30A,TO-247
HGTG30N60B3D
Data Sheet April 2004
60A, 600V, UFS Series N-Channel IGBT with Anti-Parallel Hyperfast Diode
The HGTG30N60B3D is a MOS gated high voltage switching device combining the best features of MOSFETs and bipolar transistors.
This device has the high input impedance of a MOSFET and the low on-state conduction loss of a bipolar transistor. The much lower on-state voltage drop varies only moderately between 25oC and 150oC. The IGBT used is the development type TA49170. The diode used in anti-parallel with the IGBT is the development type TA49053. The IGBT is ideal for many high voltage switching applications operating at moderate frequencies where low conduction losses are essential, such as: AC and DC motor controls, power supplies and drivers for solenoids, relays and contactors. Formerly Developmental Type TA49172.
Packaging
- Тип транзистора: IGBT
- DC Collector Current: 60 А
- Collector Emitter Voltage Vces: 1.9 В
- Power Dissipation Max: 208 Вт
- Collector Emitter Voltage V(br)ceo: 600 В
- Operating Temperature Range: -55°C to +150°C
- Корпус транзистора: TO-247
- Количество выводов: 3
