Datasheet HGTG40N60B3 - Fairchild Даташит IGBT, N 600 В TO-247 — Даташит
Fairchild HGTG40N60B3
Наименование модели: HGTG40N60B3
33 предложений от 18 поставщиков
FAIRCHILD SEMICONDUCTOR HGTG40N60B3IGBT Single Transistor, 70 A, 2 V, 290 W, 600 V, TO-247, 3 Pins
HGTG40N60B3
283 ₽
HGTG40N60B3
от 563 ₽
HGTG40N60B3
922 ₽
HGTG40N60B3_Q
Fairchild
Производитель: Fairchild
Описание: IGBT, N 600 В TO-247
data sheetСкачать Data Sheet
HGTG40N60B3
Data Sheet November 2004 File Number
70A, 600V, UFS Series N-Channel IGBT
The HGTG40N60B3 is a MOS gated high voltage switching device combining the best features of MOSFETs and bipolar transistors.
The device has the high input impedance of a MOSFET and the low on-state conduction loss of a bipolar transistor. The much lower on-state voltage drop varies only moderately between 25oC and 150oC. The IGBT is ideal for many high voltage switching applications operating at moderate frequencies where low conduction losses are essential, such as: AC and DC motor controls, power supplies and drivers for solenoids, relays and contactors. Formerly Developmental Type TA49052.
Features
  • Тип транзистора: IGBT
  • DC Collector Current: 70 А
  • Collector Emitter Voltage Vces: 2 В
  • Power Dissipation Max: 290 Вт
  • Collector Emitter Voltage V(br)ceo: 600 В
  • Operating Temperature Range: -55°C to +150°C
  • Корпус транзистора: TO-247
  • Количество выводов: 3
  • Current Ic Continuous a Max: 70 А
  • Package / Case: TO-247
  • Power Dissipation: 290 Вт
  • Termination Type: Through Hole
  • Voltage Vces: 600 В
Дополнительные аксессуары:
  • Fischer Elektronik - WLK 5
На английском языке: Datasheet HGTG40N60B3 - Fairchild IGBT, N 600 V TO-247
