Datasheet HGTP20N60A4 - Fairchild Даташит IGBT, N, TO-220 — Даташит
Наименование модели: HGTP20N60A4
Купить HGTP20N60A4 на РадиоЛоцман.Цены — от 65 до 284 ₽29 предложений от 19 поставщиков Биполярные транзисторы с изолированным затвором (IGBT) 600V N-Channel IGBT SMPS Series | |||
| HGTP20N60A4 ON Semiconductor | 125 ₽ | ||
| HGTP20N60A4 ON Semiconductor | 146 ₽ | ||
| HGTP20N60A4 ON Semiconductor | от 174 ₽ | ||
| HGTP20N60A4 ON Semiconductor | 224 ₽ | ||
Производитель: Fairchild
Описание: IGBT, N, TO-220
HGTG20N60A4, HGTP20N60A4
Data Sheet December 2001
600V, SMPS Series N-Channel IGBTs
The HGTG20N60A4 and HGTP20N60A4 are MOS gated high voltage switching devices combining the best features of MOSFETs and bipolar transistors.
These devices have the high input impedance of a MOSFET and the low on-state conduction loss of a bipolar transistor. The much lower on-state voltage drop varies only moderately between 25 oC and 150oC. This IGBT is ideal for many high voltage switching applications operating at high frequencies where low conduction losses are essential. This device has been optimized for high frequency switch mode power supplies. Formerly Developmental Type TA49339.
Features
- Тип транзистора: IGBT
- DC Collector Current: 70 А
- Collector Emitter Voltage Vces: 2.7 В
- Power Dissipation Max: 290 Вт
- Collector Emitter Voltage V(br)ceo: 600 В
- Корпус транзистора: TO-220AB
- Количество выводов: 3
- SVHC: No SVHC (18-Jun-2010)
- Current Ic Continuous a Max: 70 А
- Current Temperature: 25°C
- Fall Time tf: 32 нс
- Количество транзисторов: 1
- Package / Case: TO-220AB
- Pin Format: GCE
- Power Dissipation: 290 Вт
- Power Dissipation Pd: 290 Вт
- Power Dissipation Ptot Max: 290 Вт
- Pulsed Current Icm: 280 А
- Rise Time: 12 нс
- SVHC (Secondary): Bis (2-ethyl(hexyl)phthalate) (DEHP) (18-Jun-2010)
- Termination Type: Through Hole
- Полярность транзистора: N
- Voltage Vces: 600 В
Дополнительные аксессуары:
- Fischer Elektronik - WLK 5
