Datasheet HGTP7N60A4 - Fairchild Даташит IGBT, N, TO-220 — Даташит
Наименование модели: HGTP7N60A4
23 предложений от 23 поставщиков IGBT 600V 34A 125W TO220AB. IGBT 600V 34A 125W Through Hole TO-220-3. Transistors - IGBTs - Single | |||
| HGTP7N60A4 ON Semiconductor | 37 ₽ | ||
| HGTP7N60A4_NL Fairchild | 53 ₽ | ||
| HGTP7N60A4D | 322 ₽ | ||
| HGTP7N60A4 Fairchild | по запросу | ||
Производитель: Fairchild
Описание: IGBT, N, TO-220
HGT1S7N60A4S9A, HGTG7N60A4 HGTP7N60A4
Data Sheet September 2004
600V, SMPS Series N-Channel IGBT
The HGT1S7N60A4S9A, HGTG7N60A4 and HGTP7N60A4 are MOS gated high voltage switching devices combining the best features of MOSFETs and bipolar transistors.
These devices have the high input impedance of a MOSFET and the low on-state conduction loss of a bipolar transistor. The much lower on-state voltage drop varies only moderately between 25oC and 150oC. This IGBT is ideal for many high voltage switching applications operating at high frequencies where low conduction losses are essential. This device has been optimized for high frequency switch mode power supplies. Formerly Developmental Type TA49331.
Features
- Тип транзистора: IGBT
- DC Collector Current: 34 А
- Collector Emitter Voltage Vces: 2.7 В
- Power Dissipation Max: 125 Вт
- Collector Emitter Voltage V(br)ceo: 600 В
- Корпус транзистора: TO-220AB
- Количество выводов: 3
- SVHC: No SVHC (18-Jun-2010)
- Current Ic Continuous a Max: 34 А
- Current Temperature: 25°C
- Fall Time tf: 45 нс
- Количество транзисторов: 1
- Package / Case: TO-220AB
- Pin Format: GCE
- Power Dissipation: 125 Вт
- Power Dissipation Pd: 125 Вт
- Power Dissipation Ptot Max: 125 Вт
- Pulsed Current Icm: 56 А
- Rise Time: 11 нс
- SVHC (Secondary): Bis (2-ethyl(hexyl)phthalate) (DEHP) (18-Jun-2010)
- Termination Type: Through Hole
- Полярность транзистора: N
- Voltage Vces: 600 В
Дополнительные аксессуары:
- Fischer Elektronik - WLK 5
