Datasheet HGTG12N60C3D - Fairchild Даташит IGBT, N, 3-TO-247 — Даташит
Наименование модели: HGTG12N60C3D
20 предложений от 20 поставщиков Дискретные полупроводники Транзисторы — биполярные с изолированным затвором (IGBT) — одиночные | |||
| HGTG12N60C3D ON Semiconductor | 333 ₽ | ||
| HGTG12N60C3D, 24A/600V N- ON Semiconductor | 510 ₽ | ||
| HGTG12N60C3D Harris | 951 ₽ | ||
| HGTG12N60C3D Fairchild | по запросу | ||
Производитель: Fairchild
Описание: IGBT, N, 3-TO-247
HGTG12N60C3D
Data Sheet December 2001
24A, 600V, UFS Series N-Channel IGBT with Anti-Parallel Hyperfast Diode
The HGTG12N60C3D is a MOS gated high voltage switching device combining the best features of MOSFETs and bipolar transistors.
The device has the high input impedance of a MOSFET and the low on-state conduction loss of a bipolar transistor. The much lower on-state voltage drop varies only moderately between 25oC and 150oC. The IGBT used is the development type TA49123. The diode used in anti parallel with the IGBT is the development type TA49061. The IGBT is ideal for many high voltage switching applications operating at moderate frequencies where low conduction losses are essential. Formerly Developmental Type TA49117.
Features
- Тип транзистора: IGBT
- DC Collector Current: 24 А
- Collector Emitter Voltage Vces: 2 В
- Power Dissipation Max: 104 Вт
- Collector Emitter Voltage V(br)ceo: 600 В
- Корпус транзистора: TO-247
- Количество выводов: 3
- Current Ic Continuous a Max: 24 А
- Package / Case: TO-247
- Power Dissipation: 104 Вт
- Termination Type: Through Hole
- Voltage Vces: 600 В
Дополнительные аксессуары:
- Fischer Elektronik - WLK 5
- Fischer Elektronik - WLPG 02
