Datasheet 27.01.8.230.0000 - Finder Даташит Реле, STEP, SPST-NO, 230VAC — Даташит
Наименование модели: 27.01.8.230.0000
Купить 27.01.8.230.0000 на РадиоЛоцман.Цены — от 1 031 до 3 238 ₽18 предложений от 9 поставщиков Реле Мощности, Finder 27.01.8.230.0000 10A Step Relay 27.01.08.230.0000 230VAC 1 Closer 10A Max 230VAC (AC1) Max 2300V | |||
| 27.01.8.230.0000 Finder | 1 031 ₽ | ||
| 27.01.8.230.0000 Finder | от 2 140 ₽ | ||
| 27.01.8.230.0000 Finder | от 3 238 ₽ | ||
Производитель: Finder
Описание: Реле, STEP, SPST-NO, 230VAC
27 Series - Step relays 10 A Features
1 or 2 Pole electromechanical step relay, for electrically common coil and contact circuits Choice of 3 switching sequences Screw terminal connections · AC coil · Panel mount · Possible to connect illuminated push buttons with the additional part 027.00 · Cadmium free contact materials
27.01
27.05/06
- Тип реле: General Purpose
- Coil Voltage VAC Nom: 230 В
- Contact Current Max: 20 А
- Contact Voltage AC Nom: 230 В
- Coil Resistance: 6.5 кОм
- Contact Configuration: SPST
- Coil Type: AC Coil
- Coil Current: 17.5 мА
- Nom Operating Power: 4VA
- Relay Mounting: Panel
- Внешняя длина / высота: 47 мм
- Внешняя ширина: 32 мм
- External Depth: 21.5 мм
- Contact Current AC Max: 10 А
- Contact Voltage AC Max: 230 В
- Mounting Type: Panel
- No.
of Poles: 1
- Operating Temperature Max: 40°C
- Series: 27
- Temperature Operating Min: -40°C
- Type: 27 Series
- AC Coil Power: 4VA
- Approval Bodies: CE, IMQ, Gost
- Coil Voltage Max: 253 В AC
- Coil Voltage Min: 184 В AC
- Contact Material: AgNi
- Dielectric Voltage Contact to Contact: 1000 В AC
- IP / NEMA Rating: IP20
- No. of Electrical Operations: 100000
- No. of Mechanical Operations: 300000
- Switching Power Max: 500VA
