Datasheet 32.21.7.048.2000 - Finder Даташит Реле, PCB, 48 В DC — Даташит
Наименование модели: 32.21.7.048.2000
![]() Реле Мощности, Relay: electromagnetic; SPDT; Ucoil:48VDC; 6A/250VAC; 3A/30VDC | |||
32.21.7.048.2000 Finder | 233 ₽ | ||
32.21.7.048.2000 Finder | 397 ₽ | ||
32.21.7.048.2000 Finder | 441 ₽ | ||
32-21-7-048-2000 | по запросу |
Производитель: Finder
Описание: Реле, PCB, 48 В DC
32 Series - Subminiature PCB relays 6 A Features
Printed circuit mount 6 A relay 1 Pole changeover contacts or 1 Pole normally open contact · Subminiature, low profile package · Sensitive DC coil - 200 mW · Wash tight: RT III · Cadmium Free contact material option
32.21-x000
32.21-x300
- Тип реле: Subminiature
- Coil Voltage VDC Nom: 48 В
- Contact Current Max: 15 А
- Contact Voltage AC Nom: 250 В
- Coil Resistance: 11.52 кОм
- Contact Configuration: SPDT
- Coil Type: DC Coil, Sensitive
- Coil Current: 4 мА
- Nom Operating Power: 200 мВт
- Relay Mounting: PC Board
- Внешняя длина / высота: 10.7 мм
- Внешняя ширина: 20 мм
- External Depth: 10 мм
- Contact Current AC Max: 6 А
- Contact Voltage AC Max: 400 В
- Mounting Type: PCB
- No.
of Poles: 1
- Operating Temperature Max: 85°C
- Series: 32
- Temperature Operating Min: -40°C
- Type: Wash Tight
- Approval Bodies: GOST, VDE
- Approval Category: UL Recognised
- Contact Material: AgCdO
- Contact Style: CO
- Current Rating: 6 А
- DC Coil Power: 200 мВт
- Dielectric Voltage Coil to Contact: 1000 В AC
- No. of Electrical Operations: 100000
- No. of Mechanical Operations: 20000000
- Количество выводов: 5
- Operating Time: 6 мс
- Release Time: 4 мс
- Single Cycle Surge Current: 15 А
- Voltage Rating VAC: 250 В
