Datasheet 20.21.8.110.4000 - Finder Даташит Реле, STEP, MODULAR, 16 А, 110VAC — Даташит
Finder 20.21.8.110.4000
Наименование модели: 20.21.8.110.4000
37 предложений от 24 поставщиков
, Finder 20.21.8.012.4000 16A Modular Step Relay 20.21.8.012.4000 12VAC SPST-NO 16A Max 400V/AC / 30VDC (AC1) 4000VA/(
TM 202/18 V0
Weidmuller
от 12 ₽
CF2.02.18
709 ₽
Finder
1 561 ₽
20.21.8.120.000
Производитель: Finder
Описание: Реле, STEP, MODULAR, 16 А, 110VAC
data sheetСкачать Data Sheet
20 Series - Modular step relays 16 A Features
1 or 2 Pole 16 A Step relays for direct 35 mm rail (EN 60715) mounting 17.4 mm wide Test button with mechanical indicators · Choice of 6 switching sequences · AC coils and DC coils · Identification label · Possible to connect illuminated push buttons with the additional part 026.00 · 35 mm rail (EN 60715) mount · Cadmium free contact material
20.21
20.22, 24, 26, 28
  • Тип реле: Modular
  • Coil Voltage VAC Nom: 110 В
  • Contact Current Max: 30 А
  • Contact Voltage AC Nom: 250 В
  • Coil Resistance: 590 Ом
  • Contact Configuration: SPNO
  • Coil Type: AC Coil
  • Coil Current: 64 мА
  • Nom Operating Power: 6.5VA
  • Relay Mounting: DIN Rail
  • Внешняя длина / высота: 58.4 мм
  • Внешняя ширина: 17.4 мм
  • External Depth: 84 мм
  • Contact Current AC Max: 16 А
  • Contact Voltage AC Max: 240 В
  • Contact Voltage DC Max: 30 В
  • Mounting Type: DIN Rail
  • No.
    of Poles: 1
  • Operating Temperature Max: 40°C
  • Series: 20
  • Temperature Operating Min: -40°C
  • Coil Operating Lower Percent Limit: 85%
  • Coil Operating Upper Percent Limit: 110%
  • Current Rating: 16 А
  • Dielectric Strength VDC: 3.5kV
  • Switch Current Max: 16 А
  • Switched Current Max: 16 А
  • Switched Voltage Max: 400 В
  • Switching Voltage Max: 400 В
  • Voltage Rating VAC: 250 В
На английском языке: Datasheet 20.21.8.110.4000 - Finder RELAY, STEP, MODULAR, 16 A, 110VAC
