Datasheet 20.21.9.012.4000 - Finder Даташит Реле, STEP, MODULAR, 16 А, 12 В DC — Даташит
Наименование модели: 20.21.9.012.4000
![]() 21 предложений от 9 поставщиков Реле Мощности, Finder 20.21.9.012.4000 16A Modular Step Relay 20.21.9.012.4000 12VDC SPST-NO 16A Max 400V/AC / 30VDC (AC1) 4000VA/( | |||
20.21.9.012.4000 | от 4 802 ₽ | ||
20.21.9.012.4000 Finder | от 5 080 ₽ | ||
20.21.9.012.4000 | от 5 298 ₽ | ||
20.21.9.012.4000 Finder | от 5 327 ₽ |
Производитель: Finder
Описание: Реле, STEP, MODULAR, 16 А, 12 В DC
20 Series - Modular step relays 16 A Features
1 or 2 Pole 16 A Step relays for direct 35 mm rail (EN 60715) mounting 17.4 mm wide Test button with mechanical indicators · Choice of 6 switching sequences · AC coils and DC coils · Identification label · Possible to connect illuminated push buttons with the additional part 026.00 · 35 mm rail (EN 60715) mount · Cadmium free contact material
20.21
20.22, 24, 26, 28
- Тип реле: Modular
- Coil Voltage VDC Nom: 12 В
- Contact Current Max: 30 А
- Contact Voltage AC Nom: 250 В
- Coil Resistance: 27 Ом
- Contact Configuration: SPNO
- Coil Type: DC Coil
- Coil Current: 440 мА
- Nom Operating Power: 5 Вт
- Relay Mounting: DIN Rail
- Внешняя длина / высота: 58.4 мм
- Внешняя ширина: 17.4 мм
- External Depth: 84 мм
- Contact Current AC Max: 16 А
- Contact Voltage AC Max: 240 В
- Contact Voltage DC Max: 30 В
- Mounting Type: DIN Rail
- No.
of Poles: 1
- Operating Temperature Max: 40°C
- Series: 20
- Temperature Operating Min: -40°C
- Coil Operating Lower Percent Limit: 80%
- Coil Operating Upper Percent Limit: 110%
- Current Rating: 16 А
- Dielectric Strength VDC: 3.5kV
- Switch Current Max: 16 А
- Switched Current Max: 16 А
- Switched Voltage Max: 400 В
- Voltage Rating VAC: 250 В
