Datasheet 20.22.9.012.0000 - Finder Даташит Реле, STEP, MODULAR, 12 В DC — Даташит
Наименование модели: 20.22.9.012.0000
![]() 22 предложений от 9 поставщиков Промышленные/Универсальные Реле, DPST-NO DIN Rail Panel Mount Latching Relay, 16A, 12V dc | |||
20.22.9.012.0000 Finder | 2 865 ₽ | ||
20.22.9.012.0000 | от 5 352 ₽ | ||
20.22.9.012.0000 Finder | от 5 930 ₽ | ||
20.22.9.012.0000 Finder | от 7 956 ₽ |
Производитель: Finder
Описание: Реле, STEP, MODULAR, 12 В DC
20 Series - Modular step relays 16 A Features
1 or 2 Pole 16 A Step relays for direct 35 mm rail mounting mm wide button with mechanical indicators · Choice of 6 switching sequences · AC coils and DC coils · Identification label · Possible to connect illuminated push buttons with the additional part 026.00 · 35 mm rail (EN 50022) mount · Cadmium free contact material
· Test · 17.4
20.21
20.22, 24, 26, 28
- Тип реле: Modular
- Coil Voltage VDC Nom: 12 В
- Contact Current Max: 30 А
- Contact Voltage AC Nom: 250 В
- Coil Resistance: 27 Ом
- Contact Configuration: DPNO
- Coil Type: DC Coil
- Coil Current: 440 мА
- Nom Operating Power: 5 Вт
- Relay Mounting: DIN Rail
- Внешняя длина / высота: 58.4 мм
- Внешняя ширина: 17.4 мм
- External Depth: 84 мм
- Contact Current AC Max: 16 А
- Contact Voltage AC Max: 240 В
- Contact Voltage DC Max: 30 В
- Mounting Type: DIN Rail
- No.
of Poles: 2
- Operating Temperature Max: 40°C
- Series: 20
- Temperature Operating Min: -40°C
- Approval Bodies: IMQ, SEMKO
- Coil Operating Lower Percent Limit: 80%
- Coil Operating Upper Percent Limit: 110%
- Current Rating: 16 А
- Dielectric Strength VDC: 3.5kV
- Switch Current Max: 16 А
- Switched Current Max: 16 А
- Switched Voltage Max: 400 В
- Voltage Rating VAC: 250 В
