Datasheet 20.23.8.230.0000 - Finder Даташит Реле, STEP, MODULAR, 230VAC — Даташит
Наименование модели: 20.23.8.230.0000
![]() 25 предложений от 10 поставщиков Универсальное реле, серия 20, силовое, SPST-NO, SPST-NC, 230В AC, 16А | |||
202382300000 Finder | 2 134 ₽ | ||
20.23.8.230.0000 Finder | 3 247 ₽ | ||
20.23.8.230.0000 Finder | от 5 357 ₽ | ||
20.23.8.230.0000 Finder | от 6 214 ₽ |
Производитель: Finder
Описание: Реле, STEP, MODULAR, 230VAC
20 Series - Modular step relays 16 A Features
1 or 2 Pole 16 A Step relays for direct 35 mm rail mounting mm wide button with mechanical indicators · Choice of 6 switching sequences · AC coils and DC coils · Identification label · Possible to connect illuminated push buttons with the additional part 026.00 · 35 mm rail (EN 50022) mount · Cadmium free contact material
· Test · 17.4
20.21
20.22, 24, 26, 28
- Тип реле: Modular
- Coil Voltage VAC Nom: 230 В
- Contact Current Max: 30 А
- Contact Voltage AC Nom: 250 В
- Coil Resistance: 2.5 кОм
- Contact Configuration: DPCO
- Coil Type: AC Coil
- Coil Current: 28 мА
- Nom Operating Power: 6.5VA
- Relay Mounting: DIN Rail
- Внешняя длина / высота: 58.4 мм
- Внешняя ширина: 17.4 мм
- External Depth: 84 мм
- Contact Current AC Max: 16 А
- Contact Voltage AC Max: 240 В
- Contact Voltage DC Max: 30 В
- Mounting Type: DIN Rail
- No.
of Poles: 2
- Operating Temperature Max: 40°C
- Series: 20
- Temperature Operating Min: -40°C
- Approval Bodies: IMQ, SEMKO
- Coil Operating Lower Percent Limit: 80%
- Coil Operating Upper Percent Limit: 110%
- Current Rating: 16 А
- Dielectric Strength VDC: 3.5kV
- Switch Current Max: 16 А
- Switched Current Max: 16 А
- Switched Voltage Max: 400 В
- Voltage Rating VAC: 250 В
