Datasheet 22.21.8.110.4000 - Finder Даташит Реле, MODULAR, SPNO, 20 А, 110VAC — Даташит
Наименование модели: 22.21.8.110.4000
![]() 19 предложений от 7 поставщиков Реле Мощности, RELAY, MODULAR, SPNO, 20A, 110VAC; Relay Type: Modular; Coil Voltage VAC Nom: 110V; Contact Current Max: 30A; Contact... | |||
22.21.8.110.4000 | от 4 690 ₽ | ||
22.21.8.110.4000 Finder | от 4 831 ₽ | ||
22.21.8.110.4000 | 7 115 ₽ | ||
22.21.8.110.4000 Finder | от 7 176 ₽ |
Производитель: Finder
Описание: Реле, MODULAR, SPNO, 20 А, 110VAC
22 Series - Modular monostable relays 20 A Features
1 or 2 pole, 20 A relay for direct 35 mm rail (EN 60715) mounting 17.4 mm wide Test button · Identification label · AC coils and DC coils · 35 mm rail (EN 60715) mount · Cadmium free contact material
22.21
22.22
- Тип реле: Modular
- Coil Voltage VAC Nom: 110 В
- Contact Current Max: 30 А
- Contact Voltage AC Nom: 250 В
- Coil Resistance: 970 Ом
- Contact Configuration: SPST
- Coil Type: AC Coil, Monostable
- Coil Current: 26 мА
- Nom Operating Power: 3VA
- Relay Mounting: DIN Rail
- Внешняя длина / высота: 58.4 мм
- Внешняя ширина: 17.4 мм
- External Depth: 84 мм
- Contact Current AC Max: 30 А
- Mounting Type: DIN Rail
- No.
of Poles: 1
- Operating Temperature Max: 40°C
- Series: 22
- Temperature Operating Min: -40°C
- Approval Category: IP20
- Coil Operating Lower Percent Limit: 85%
- Coil Operating Upper Percent Limit: 110%
- Current Rating: 20 А
- Dielectric Strength VDC: 3.5kV
- Switch Current Max: 20 А
- Switched Current Max: 20 А
- Switched Voltage Max: 400 В
- Voltage Rating VAC: 250 В
