Datasheet 100-C09DJ10 - Rockwell Automation Даташит CONTACTOR, 9 А, 24 В DC — Даташит
Rockwell Automation 100-C09DJ10
Наименование модели: 100-C09DJ10
Производитель: Rockwell Automation
Описание: CONTACTOR, 9 А, 24 В DC
data sheetСкачать Data Sheet
Mini-Contactors and Contactors
· Bulletin 100-M / CA 4 · Bulletin 100-C · Bulletin CAB6 / CA 6 2.5 ...
4.3 kW 4 ... 45 kW 47 ... 238 kW
Overview ............................................................................. 4-2 Product Selection AC Control ....................................................................... 4-4 DC Control ....................................................................... 4-6 Special Contactor Version ............................................... 4-8 Accessories Accessories ................................................................... 4-12 Connecting Components ............................................... 4-18 Labeling Materials ......................................................... 4-19 Replacement Parts ........................................................ 4-19 Technical Information Performance Data / Characteristics .............................. 4-22 Weight ....................................................................
  • Тип реле: Contactor
  • Coil Voltage VDC Nom: 24 В
  • Contact Configuration: DPCO
  • Внешняя длина / высота: 81 мм
  • Внешняя ширина: 45 мм
  • External Depth: 112.5 мм
  • Contact Voltage AC Max: 500 В
  • Contact Voltage DC Max: 440 В
  • Mounting Type: DIN Rail
  • No. of Poles: 3
  • Operating Temperature Max: 60°C
  • Series: 100C
  • Temperature Operating Min: -25°C
  • Approval Bodies: CE, UL, CSA, IEC947, EN60 947, VDE 0660, UL 508, CSA22.2
  • IP / NEMA Rating: 2X
  • Main Contact Current AC1 Max: 32 А
  • Main Contact Current AC3 Max: 9 А
  • Output Voltage Max: 415 В
  • Output Voltage Min: 400 В
  • Switching AC1 Power Max: 4kW
100C09DJ10, 100 C09DJ10
На английском языке: Datasheet 100-C09DJ10 - Rockwell Automation CONTACTOR, 9 A, 24 V DC
Политика конфиденциальности
