Datasheet 100-C12DJ10 - Rockwell Automation Даташит CONTACTOR, 12 А, 24 В DC — Даташит
Наименование модели: 100-C12DJ10
Производитель: Rockwell Automation
Описание: CONTACTOR, 12 А, 24 В DC
Mini-Contactors and Contactors
· Bulletin 100-M / CA 4 · Bulletin 100-C · Bulletin CAB6 / CA 6 2.5 ...
4.3 kW 4 ... 45 kW 47 ... 238 kW
Overview ............................................................................. 4-2 Product Selection AC Control ....................................................................... 4-4 DC Control ....................................................................... 4-6 Special Contactor Version ............................................... 4-8 Accessories Accessories ................................................................... 4-12 Connecting Components ............................................... 4-18 Labeling Materials ......................................................... 4-19 Replacement Parts ........................................................ 4-19 Technical Information Performance Data / Characteristics .............................. 4-22 Weight ....................................................................
- Тип реле: Contactor
- Coil Voltage VDC Nom: 24 В
- Contact Configuration: DPCO
- Внешняя длина / высота: 81 мм
- Внешняя ширина: 45 мм
- External Depth: 112.5 мм
- Contact Voltage AC Max: 500 В
- Contact Voltage DC Max: 440 В
- Mounting Type: DIN Rail
- No. of Poles: 3
- Operating Temperature Max: 60°C
- Series: 100-C
- Temperature Operating Min: -25°C
- Approval Bodies: CE, UL, CSA, IEC947, EN60 947, VDE 0660, UL 508, CSA22.2
- IP / NEMA Rating: 2X
- Main Contact Current AC1 Max: 32 А
- Main Contact Current AC3 Max: 12 А
- Output Voltage Max: 415 В
- Output Voltage Min: 400 В
- Switching AC1 Power Max: 5.5kW
100C12DJ10, 100 C12DJ10
