Datasheet G2R-1A-E-DC24 - Omron Даташит Реле, SPST, 24 В DC — Даташит
Omron G2R-1A-E-DC24
Наименование модели: G2R-1A-E-DC24
42 предложений от 19 поставщиков
Промышленные/Универсальные Реле, Electromechanical Relay SPST-NO 16A 24VDC 1.1KΩ Through Hole
G2R1AEDC24BYOMI
Omron
103 ₽
G2R1AEDC24BYOMI
Omron
103 ₽
ICdarom.ru
G2R-1A-E-DC24
Omron
от 145 ₽
Эиком
G2R-1A-E-DC24
Omron
от 815 ₽
Производитель: Omron
Описание: Реле, SPST, 24 В DC
data sheetСкачать Data Sheet
Power PCB Relay
G2R
· Creepage distance of 8.0 mm (0.31) min.
between coil and contact. · Dual-winding latching type available. · Plug-in and quick-connect terminals available. · High sensitivity (360 mW) and high capacity (16 A) types available. · Highly stable magnetic circuit for latching endurance and excellent resistance to vibration and shock. · Safety-oriented design assuring high surge resistance: 10,000 V min. between coil and contacts. · UL, CSA approved, marked with CE.
Ordering Information
To order: Select the part number and add the desired coil voltage rating (e.g., G2R-14-DC12).
  • Тип реле: Power
  • Coil Voltage VDC Nom: 24 В
  • Contact Current Max: 16 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 1.1 кОм
  • Contact Configuration: SPST
  • Coil Type: DC Coil, Monostable
  • Coil Current: 21.8 мА
  • Nom Operating Power: 530 мВт
  • Relay Mounting: PC Board
  • Внешняя длина / высота: 25.5 мм
  • Внешняя ширина: 29 мм
  • External Depth: 13 мм
  • Contact Current AC Max: 10 А
  • Contact Current DC Max: 10 А
  • Contact Voltage AC Max: 250 В
  • Contact Voltage DC Max: 30 В
  • Mounting Type: PCB
  • No. of Poles: 1
  • Operating Temperature Max: 70°C
  • Series: G2R
  • Temperature Operating Min: -40°C
  • Type: High Capacity - Semi-sealed
  • Approval Bodies: CSA, SEV, Semko, VDE, TUV
  • Approval Category: UL Recognised
  • Contact Current Max: 10 А
  • Contact Current Min: 100 мА
  • Contact Material: AgCdO
  • Contact Resistance: 100 MOhm
  • Contact Style: NO
  • DC Coil Power: 530 мВт
  • Dielectric Voltage Coil to Contact: 5000 В AC
  • Dielectric Voltage Contact to Contact: 1000 В AC
  • Insulation Resistance: 1000 MOhm
G2R1AEDC24, G2R 1A E DC24
На английском языке: Datasheet G2R-1A-E-DC24 - Omron RELAY, SPST, 24 V DC
