Datasheet G2R-2-SND-DC24(S) - Omron Даташит Реле, DPDT, 24 В DC — Даташит
Omron G2R-2-SND-DC24(S)
Наименование модели: G2R-2-SND-DC24(S)
21 предложений от 13 поставщиков
Реле электромагнитное, промежуточное, Uобмотки 24В
G2R2SNDDC24S
Omron
624 ₽
G2R2SNDDC24S
Omron
624 ₽
G2R2SNDDC24S
Omron
1 092 ₽
ТаймЧипс
G2R2SNDDC24
Omron
Производитель: Omron
Описание: Реле, DPDT, 24 В DC
data sheetСкачать Data Sheet
Power PCB Relay
G2R
· Creepage distance of 8.0 mm (0.31) min.
between coil and contact. · Dual-winding latching type available. · Plug-in and quick-connect terminals available. · High sensitivity (360 mW) and high capacity (16 A) types available. · Highly stable magnetic circuit for latching endurance and excellent resistance to vibration and shock. · Safety-oriented design assuring high surge resistance: 10,000 V min. between coil and contacts. · UL, CSA approved, marked with CE.
Ordering Information
To order: Select the part number and add the desired coil voltage rating (e.g., G2R-14-DC12).
  • Тип реле: Power
  • Coil Voltage VDC Nom: 24 В
  • Contact Current Max: 5 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 1.1 кОм
  • Contact Configuration: DPDT
  • Coil Type: DC Coil, Monostable
  • Coil Current: 21.8 мА
  • Nom Operating Power: 530 мВт
  • Relay Mounting: Plug-In
  • Внешняя длина / высота: 28 мм
  • Внешняя ширина: 29 мм
  • External Depth: 13 мм
  • Contact Current AC Max: 5 А
  • Contact Current DC Max: 5 А
  • Contact Voltage AC Max: 250 В
  • Contact Voltage DC Max: 30 В
  • Mounting Type: Plug-In
  • No. of Poles: 2
  • Operating Temperature Max: 70°C
  • Series: G2R
  • Temperature Operating Min: -40°C
  • Type: LED indicator and surge suppression diode
  • Approval Bodies: CSA, SEV, Semko, VDE, TUV
  • Approval Category: UL Recognised
  • Contact Current Min: 100 мА
  • Contact Material: AgCdO
  • Contact Resistance: 100 MOhm
  • DC Coil Power: 530 мВт
  • Dielectric Voltage Coil to Contact: 5000 В AC
  • Dielectric Voltage Contact to Contact: 1000 В AC
  • Insulation Resistance: 1000 MOhm
G2R2SNDDC24(S), G2R 2 SND DC24(S)
На английском языке: Datasheet G2R-2-SND-DC24(S) - Omron RELAY, DPDT, 24 V DC
