Datasheet G2RL-1 24DC - Omron Даташит Реле, PCB, SPCO, 24 В DC — Даташит
Omron G2RL-1 24DC
Наименование модели: G2RL-1 24DC
22 предложений от 15 поставщиков
Промышленные/Универсальные Реле, Power Relay 24VDC 12A SPDT (29mm 12.7mm 15.7mm) THT
G2RL124DC
Omron
87 ₽
Microfind
G2RL124DC
Omron
102 ₽
Romstore
Россия, Беларусь
G2RL124DC
от 440 ₽
G2RL124DC
Производитель: Omron
Описание: Реле, PCB, SPCO, 24 В DC
data sheetСкачать Data Sheet
PCB Relay
Next-generation PCB Relay Available in 24 Models
Low profile: 15.7 mm max.
in height Contains no lead inside and features cadmium-free contacts ensuring environment-friendly use. Conforms to VDE0435 (VDE approval: C250 insulation grade for flux protection models; B400 insulation grade for fully sealed models), UL508 and CSA22.2. Meets VDE0700 requirements for household products according to VDE0110. Clearance and creepage distance: 10 mm/10 mm. Tracking resistance: CTI>250 (Both standard and class F type) UL1446 Class F Coil Insulation system available. High sensitivity: 400 mW
G2RL
VDE
  • Тип реле: Power
  • Coil Voltage VDC Nom: 24 В
  • Contact Current Max: 12 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 24 В
  • Coil Resistance: 1.44 кОм
  • Contact Configuration: SPCO
  • Coil Type: DC Coil, Sensitive
  • Coil Current: 16.7 мА
  • Nom Operating Power: 400 мВт
  • Relay Mounting: PC Board
  • Внешняя длина / высота: 15.7 мм
  • Внешняя ширина: 12.7 мм
  • External Depth: 29 мм
  • Contact Current AC Max: 12 А
  • Contact Current DC Max: 12 А
  • Contact Voltage AC Max: 240 В
  • Contact Voltage DC Max: 30 В
  • Mounting Type: PCB
  • No. of Poles: 1
  • Operating Temperature Max: 85°C
  • Series: G2RL
  • Temperature Operating Min: -40°C
  • Type: Flux protected
  • Approval Bodies: UL, CSA, VDE
  • Coil Operating Lower Percent Limit: 70%
  • Coil Operating Upper Percent Limit: 130%
  • DC Coil Power: 400 мВт
  • Operating Time: 7 мс
  • Release Time: 5 мс
  • Switch Current Max: 12 А
G2RL1 24DC, G2RL 1 24DC
На английском языке: Datasheet G2RL-1 24DC - Omron RELAY, PCB, SPCO, 24 V DC
