Datasheet G2RL-1A-E-CV DC24 - Omron Даташит Реле, PCB, SPST-NO, 24 В DC, 16 А — Даташит
Omron G2RL-1A-E-CV DC24
Наименование модели: G2RL-1A-E-CV DC24
6 предложений от 5 поставщиков
, Power Relay 24VDC 16A SPST-NO (( 29mm 12.7mm 15.7mm)) Through Hole
G2RL-1A-E-CV-DC24
Omron
120 ₽
G2RL-1A-E-CV-DC24
Omron
120 ₽
G2RL-1A-E-CV-DC24
Omron
175 ₽
G2RL-1A-E-CV-DC24
Omron
от 770 ₽
Производитель: Omron
Описание: Реле, PCB, SPST-NO, 24 В DC, 16 А
data sheetСкачать Data Sheet
PCB Relay
G2RL
A Power Relay with Various Models
High-sensitivity (250 mW) and High-capacity
(16 A) Models available.
Low profile: 15.7 mm max. in height Conforms to VDE (EN61810-1), UL508 and CSA22.2. Meets EN60335-1 requirements for household products. Clearance and creepage distance: 10 mm/10 mm. Tracking resistance: CTI>250 Coil Insulation system: Class F (UL1446) RoHS Compliant
  • Тип реле: Power
  • Coil Voltage VDC Nom: 24 В
  • Contact Current Max: 16 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 24 В
  • Coil Resistance: 1.44 кОм
  • Contact Configuration: SPST
  • Coil Type: DC Coil, Sensitive
  • Coil Current: 10.4 мА
  • Nom Operating Power: 400 мВт
  • Relay Mounting: PC Board
  • Внешняя длина / высота: 15.7 мм
  • Внешняя ширина: 12.7 мм
  • External Depth: 29 мм
  • Contact Current AC Max: 16 А
  • Contact Current DC Max: 16 А
  • Contact Voltage AC Max: 440 В
  • Contact Voltage DC Max: 300 В
  • Mounting Type: PCB
  • No. of Poles: 1
  • Operating Temperature Max: 85°C
  • Series: G2RL
  • Temperature Operating Min: -40°C
  • Coil Operating Lower Percent Limit: 10%
  • Coil Operating Upper Percent Limit: 70%
  • Contact Material: Ag Alloy (Cd free)
  • DC Coil Power: 250 мВт
  • Operating Time: 15 мс
  • Release Time: 5 мс
  • Switching Current AC Max: 16 А
  • Switching Current DC Max: 16 А
  • Switching Power Max: 4000VA
  • Voltage DC: 30 В
  • Voltage Rating VAC: 250 В
G2RL1AECV DC24, G2RL 1A E CV DC24
На английском языке: Datasheet G2RL-1A-E-CV DC24 - Omron RELAY, PCB, SPST-NO, 24 V DC, 16 A
