Datasheet G2RL-1ATP5-E 24DC - Omron Даташит Реле, PCB, SPCO, 24 В DC — Даташит
Наименование модели: G2RL-1ATP5-E 24DC
![]() 14 предложений от 14 поставщиков Реле Мощности, OMRON ELECTRONIC COMPONENTS G2RL1ATP5EDC12 Power Relay, SPST-NO, 12VDC, 16A, G2RL Series, Through Hole, Non Latching | |||
G2RL-1ATP5-E-DC24 Omron | 981 ₽ | ||
G2RL1ATP5EDC12 | 44 006 ₽ | ||
G2RL-1ATP5-E DC24 Omron | по запросу | ||
G2RL-1ATP5-E-DC24 Omron | по запросу |
Производитель: Omron
Описание: Реле, PCB, SPCO, 24 В DC
PCB Relay
PCB Power Relay with Quick-connect Terminals
High switching capacity: 250 VAC, 16 A at 105°C.
Ideal for high temperature applications. Coil insulation: Class F (UL508). Low profile for total size reduction. Easy wiring with quick-connect terminals. Model with 5-mm pitch (RAST5) is also available.
G2RL-TP
RoHS Compliant
- Тип реле: Power
- Coil Voltage VDC Nom: 24 В
- Contact Current Max: 16 А
- Contact Voltage AC Nom: 250 В
- Coil Resistance: 1.44 кОм
- Contact Configuration: SPST
- Coil Type: DC Coil
- Coil Current: 16.7 мА
- Nom Operating Power: 400 мВт
- Relay Mounting: PC Board
- Внешняя длина / высота: 15.9 мм
- Внешняя ширина: 29.6 мм
- External Depth: 12.6 мм
- Contact Current AC Max: 16 А
- Contact Voltage AC Max: 250 В
- Mounting Type: PCB
- No. of Poles: 1
- Operating Temperature Max: 105°C
- Series: G2RL-TP
- Temperature Operating Min: -40°C
- Approval Bodies: CSA, VDE
- Approval Category: UL Recognised
- Contact Material: Ag alloy
- Contact Resistance: 100 MOhm
- Current Rating: 16 А
- Dielectric Voltage Coil to Contact: 5000 В AC
- Dielectric Voltage Contact to Contact: 1000 В AC
- Insulation Resistance: 1000 MOhm
- Insulation Resistance Voltage: 500 В DC
- Operating Time: 15 мс
- Power Consumption: 400 мВт
- Release Time: 5 мс
- Row Pitch: 5 мм
- Switching Power Max: 4000VA
- Switching Voltage Max: 440 В AC
- Terminal Type: Quick Connect
G2RL1ATP5E 24DC, G2RL 1ATP5 E 24DC
