Datasheet G2RL-2 48DC - Omron Даташит Реле, PCB, DPCO, 48 В DC — Даташит
Omron G2RL-2 48DC
Наименование модели: G2RL-2 48DC
Промышленные/Универсальные Реле, Electromechanical Relay DPDT 8A 48VDC 5.358KΩ Through Hole
Элрус
G2RL248DC
Omron
97 ₽
G2RL248DC
Omron
117 ₽
СЭлКом
G2RL248DC
Omron
136 ₽
Элитан
G2RL248DC
Omron
182 ₽
Производитель: Omron
Описание: Реле, PCB, DPCO, 48 В DC
data sheetСкачать Data Sheet
PCB Relay
Next-generation PCB Relay Available in 24 Models
Low profile: 15.7 mm max.
in height Contains no lead inside and features cadmium-free contacts ensuring environment-friendly use. Conforms to VDE0435 (VDE approval: C250 insulation grade for flux protection models; B400 insulation grade for fully sealed models), UL508 and CSA22.2. Meets VDE0700 requirements for household products according to VDE0110. Clearance and creepage distance: 10 mm/10 mm. Tracking resistance: CTI>250 (Both standard and class F type) UL1446 Class F Coil Insulation system available. High sensitivity: 400 mW
G2RL
VDE
  • Тип реле: Power
  • Coil Voltage VDC Nom: 48 В
  • Contact Current Max: 8 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 5.358 кОм
  • Contact Configuration: DPCO
  • Coil Type: DC Coil, Sensitive
  • Coil Current: 8.96 мА
  • Nom Operating Power: 430 мВт
  • Relay Mounting: PC Board
  • Внешняя длина / высота: 15.7 мм
  • Внешняя ширина: 12.7 мм
  • External Depth: 29 мм
  • Contact Current AC Max: 8 А
  • Contact Current DC Max: 8 А
  • Contact Voltage AC Max: 240 В
  • Contact Voltage DC Max: 30 В
  • Mounting Type: PCB
  • No. of Poles: 2
  • Operating Temperature Max: 85°C
  • Series: G2RL
  • Temperature Operating Min: -40°C
  • Type: Flux protected
  • Approval Bodies: UL, CSA, VDE
  • Coil Operating Lower Percent Limit: 70%
  • Coil Operating Upper Percent Limit: 130%
  • DC Coil Power: 430 мВт
  • Operating Time: 7 мс
  • Release Time: 5 мс
  • Switch Current Max: 8 А
G2RL2 48DC, G2RL 2 48DC
На английском языке: Datasheet G2RL-2 48DC - Omron RELAY, PCB, DPCO, 48 V DC
