Datasheet G4A-1AE 12DC - Omron Даташит Реле, PCB, SPNO, 12 В DC — Даташит
Наименование модели: G4A-1AE 12DC
![]() 27 предложений от 12 поставщиков Реле силовое 20А один контакт на замыкание катушка 12В 30.5х16х33.5мм монтаж в отверстие quick-connect (G4A-1A-E) | |||
G4A1AE12DC Omron | от 105 ₽ | ||
G4A1AE12DC Omron | 133 ₽ | ||
G4A1AE12DC Omron | по запросу | ||
G4A1AE12DC | по запросу |
Производитель: Omron
Описание: Реле, PCB, SPNO, 12 В DC
Special-purpose PCB Relay
Miniature Single-pole Relay with 80-A Surge Current and 20-A Switching Current
I I I I I
G4A
Ideal for motor switching.
Miniature, relay with high switching power and long endurance. Creepage distance conforms to UL and CSA standards. Highly noise-resistive insulation materials employed. Standard model available with flux protection construction.
- Тип реле: Power
- Coil Voltage VDC Nom: 12 В
- Contact Current Max: 20 А
- Contact Voltage AC Nom: 250 В
- Coil Resistance: 160 Ом
- Contact Configuration: SPST
- Coil Type: DC Coil
- Coil Current: 75 мА
- Nom Operating Power: 900 мВт
- Relay Mounting: PC Board
- Внешняя длина / высота: 23.5 мм
- Внешняя ширина: 30.5 мм
- External Depth: 16 мм
- Contact Current AC Max: 20 А
- Contact Current DC Max: 20 А
- Contact Voltage AC Max: 250 В
- Contact Voltage DC Max: 30 В
- Mounting Type: PCB
- No. of Poles: 1
- Operating Temperature Max: 60°C
- Series: G4 А
- Temperature Operating Min: -20°C
- Approval Bodies: CSA and VDE
- Approval Category: UL Recognised
- Coil Operating Lower Percent Limit: 70%
- Coil Operating Upper Percent Limit: 160%
- Contact Resistance: 100 MOhm
- Current Rating: 75 мА
- DC Coil Power: 900 мВт
- Dielectric Strength: 1000V/m
- Dielectric Voltage Coil to Contact: 4500 В AC
- Dielectric Voltage Contact to Contact: 1000 В AC
- Lead Spacing: 0.8 мм
- Mechanical Life: 2,000,000 Operations
- Operating Time: 20 мс
G4A1AE 12DC, G4A 1AE 12DC
