Datasheet G4A-1AE 24DC - Omron Даташит Реле, PCB, SPNO, 24 В DC — Даташит
Наименование модели: G4A-1AE 24DC
![]() 23 предложений от 14 поставщиков Реле силовое катушка 24В 20A один контакт на замыкание (30.5x16x33.5)мм монтаж в отверстие | |||
G4A1AE24DC Omron | от 160 ₽ | ||
G4A-1AE-24DC | 220 ₽ | ||
G4A1AE24DC Omron | 329 ₽ | ||
G4A1AE24DC Omron | 9 665 ₽ |
Производитель: Omron
Описание: Реле, PCB, SPNO, 24 В DC
Special-purpose PCB Relay
Miniature Single-pole Relay with 80-A Surge Current and 20-A Switching Current
I I I I I
G4A
Ideal for motor switching.
Miniature, relay with high switching power and long endurance. Creepage distance conforms to UL and CSA standards. Highly noise-resistive insulation materials employed. Standard model available with flux protection construction.
- Тип реле: Power
- Coil Voltage VDC Nom: 24 В
- Contact Current Max: 20 А
- Contact Voltage AC Nom: 250 В
- Coil Resistance: 640 Ом
- Contact Configuration: SPST
- Coil Type: DC Coil
- Coil Current: 37.5 мА
- Nom Operating Power: 900 мВт
- Relay Mounting: PC Board
- Внешняя длина / высота: 23.5 мм
- Внешняя ширина: 30.5 мм
- External Depth: 16 мм
- Contact Current AC Max: 20 А
- Contact Current DC Max: 20 А
- Contact Voltage AC Max: 250 В
- Contact Voltage DC Max: 30 В
- Mounting Type: PCB
- No. of Poles: 1
- Operating Temperature Max: 60°C
- Series: G4 А
- Temperature Operating Min: -20°C
- Approval Bodies: CSA and VDE
- Approval Category: UL Recognised
- Coil Operating Lower Percent Limit: 70%
- Coil Operating Upper Percent Limit: 160%
- Contact Resistance: 100 MOhm
- Current Rating: 37.5 мА
- DC Coil Power: 900 мВт
- Dielectric Strength: 1000V/m
- Dielectric Voltage Coil to Contact
- Dielectric Voltage Contact to Contact: 1000 В AC
- Lead Spacing: 0.8 мм
- Mechanical Life: 2,000,000 Operations
- Operating Time: 20 мс
G4A1AE 24DC, G4A 1AE 24DC
