Datasheet G5CA-1AE 12DC - Omron Даташит Реле, PCB, SPNO, 12 В DC — Даташит
Наименование модели: G5CA-1AE 12DC
![]() 19 предложений от 9 поставщиков Промышленные/Универсальные Реле, Electromechanical Relay SPST-NO 15A 12VDC 720Ω Through Hole | |||
G5CA1AE12DC Omron | 52 ₽ | ||
G5CA1AE12DC Omron | 91 ₽ | ||
G5CA1AE12DC Omron | 72 ₽ | ||
G5CA1AE12DC Omron | 188 ₽ |
Производитель: Omron
Описание: Реле, PCB, SPNO, 12 В DC
PCB Text Power Relay G5CA Flat Relays that Switch 10-A/15-A Loads with New Quick-connect Terminals
ROHS compliant.
Ideal for switching power in household
appliances or for outputs from industrial devices.
Sub-miniature dimensions: 22 x 16 x 11 mm
(L x W x H).
- Тип реле: Power
- Coil Voltage VDC Nom: 12 В
- Contact Current Max: 15 А
- Contact Voltage AC Nom: 110 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 720 Ом
- Contact Configuration: SPST
- Coil Type: DC Coil
- Coil Current: 16.7 мА
- Nom Operating Power: 200 мВт
- Relay Mounting: PC Board
- Внешняя длина / высота: 11 мм
- Внешняя ширина: 22 мм
- External Depth: 16 мм
- Contact Current AC Max: 15 А
- Contact Current DC Max: 15 А
- Contact Voltage AC Max: 250 В
- Contact Voltage DC Max: 125 В
- Mounting Type: PCB
- No. of Poles: 1
- Operating Temperature Max: 70°C
- Series: G5CA
- Temperature Operating Min: -25°C
- Approval Bodies: CSA, TUV
- Approval Category: UL Recognised
- Coil Operating Lower Percent Limit: 10%
- Coil Operating Upper Percent Limit: 75%
- Contact Material: AgSnin
- Contact Resistance: 30 MOhm
- DC Coil Power: 200mW
- Dielectric Voltage Coil to Contact
- Dielectric Voltage Contact to Contact: 1000 В AC
- Insulation Resistance: 1000 MOhm
- No. of Electrical Operations: 300000
G5CA1AE 12DC, G5CA 1AE 12DC
