Datasheet G5CA-1AE 5DC - Omron Даташит Реле, PCB, SPNO, 5 В DC — Даташит
Наименование модели: G5CA-1AE 5DC
![]() 5 предложений от 5 поставщиков Промышленные/Универсальные Реле, Power Relay 5VDC 10A SPST-NO (( 22mm 16mm 11mm)) Through Hole | |||
G5CA1AE5DC Omron | 94 ₽ | ||
G5CA1AE5DC Omron | 138 ₽ | ||
G5CA-1AE-5DC Omron | 429 ₽ | ||
G5CA1AE5DC | 20 944 ₽ |
Производитель: Omron
Описание: Реле, PCB, SPNO, 5 В DC
PCB Text Power Relay G5CA Flat Relays that Switch 10-A/15-A Loads with New Quick-connect Terminals
ROHS compliant.
Ideal for switching power in household
appliances or for outputs from industrial devices.
Sub-miniature dimensions: 22 x 16 x 11 mm
(L x W x H).
- Тип реле: Power
- Coil Voltage VDC Nom: 5 В
- Contact Current Max: 15 А
- Contact Voltage AC Nom: 110 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 125 Ом
- Contact Configuration: SPST
- Coil Type: DC Coil
- Coil Current: 40 мА
- Nom Operating Power: 200 мВт
- Relay Mounting: PC Board
- Внешняя длина / высота: 11 мм
- Внешняя ширина: 22 мм
- External Depth: 16 мм
- Contact Current AC Max: 15 А
- Contact Current DC Max: 15 А
- Contact Voltage AC Max: 250 В
- Contact Voltage DC Max: 125 В
- Mounting Type: PCB
- No. of Poles: 1
- Operating Temperature Max: 70°C
- Series: G5CA
- Temperature Operating Min: -25°C
- Approval Bodies: CSA, TUV
- Approval Category: UL Recognised
- Coil Operating Lower Percent Limit: 10%
- Coil Operating Upper Percent Limit: 75%
- Contact Material: AgSnin
- Contact Resistance: 30 MOhm
- DC Coil Power: 200 мВт
- Dielectric Voltage Coil to Contact: 2500 В AC
- Dielectric Voltage Contact to Contact: 1000 В AC
- Insulation Resistance: 1000 MOhm
- No. of Electrical Operations: 300000
- No. of Mechanical Operations: 20000000
G5CA1AE 5DC, G5CA 1AE 5DC
