Datasheet G5LA-1 5DC - Omron Даташит Реле, PCB, SPDT, 5 В DC — Даташит
Наименование модели: G5LA-1 5DC
![]() 24 предложений от 21 поставщиков Реле общего назначения SPDT 12VDC Class A 30mA Flux Protected | |||
G5LA-1-24DC Omron | 321 ₽ | ||
G5LA-1DC9 Omron | по запросу | ||
G5LA-1-CF 24VDC | по запросу | ||
G5LA-1-CF DC24 Omron | по запросу |
Производитель: Omron
Описание: Реле, PCB, SPDT, 5 В DC
1
PCB Relay
A Cubic, Single-pole 10A Power Relay Small size and light weight · 19.6 Ч 15.6 Ч 15.6 mm, 7.5g High Insulation · Dielectric strength 2,000V · Withstand impulse voltage 4,500V High heat resistance and tracking performance · UL class-F available (-CF model) · IEC60335 GWT compliant · Tracking resistance CTI>250 Environmental friendly (RoHS compliant)
G5LA
Ordering Information
- Тип реле: Power
- Coil Voltage VDC Nom: 5 В
- Contact Current Max: 10 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 24 В
- Coil Resistance: 69.4 Ом
- Contact Configuration: SPDT
- Coil Type: DC Coil
- Coil Current: 72 мА
- Nom Operating Power: 360 мВт
- Relay Mounting: PC Board
- Внешняя длина / высота: 15.6 мм
- Внешняя ширина: 19.6 мм
- External Depth: 15.6 мм
- Contact Current AC Max: 10 А
- Contact Current DC Max: 10 А
- Contact Voltage AC Max: 250 В
- Contact Voltage DC Max: 24 В
- Mounting Type: PCB
- No.
of Poles: 1
- Operating Temperature Max: 85°C
- Series: G5LA
- Temperature Operating Min: -40°C
- Type: Flux protection
- Approval Bodies: VDE, CQC
- Approval Category: UL Recognised
- Coil Operating Lower Percent Limit: 10%
- Coil Operating Upper Percent Limit: 75%
- Contact Material: AgSnO
- Contact Resistance: 100 MOhm
- DC Coil Power: 360 мВт
- Dielectric Voltage Coil to Contact: 2000 В AC
- Dielectric Voltage Contact to Contact: 750 В AC
- No. of Mechanical Operations: 100000
- Operating Time: 10 мс
- Release Time: 5 мс
G5LA1 5DC, G5LA 1 5DC
