Datasheet G5LA-1E 24DC - Omron Даташит Реле, PCB, SPDT, 24 В DC — Даташит
Omron G5LA-1E 24DC
Наименование модели: G5LA-1E 24DC
Промышленные/Универсальные Реле, Electromechanical Relay SPDT 5A 12VDC 400Ω Through Hole
G5LA1E12DC
Omron
39 ₽
IC Home
G5LA-1-E-CF DC12
Omron
LifeElectronics
G5LA-1-E DC24
Omron
ТаймЧипс
G5LA-1-E-CF DC5
Omron
Производитель: Omron
Описание: Реле, PCB, SPDT, 24 В DC
data sheetСкачать Data Sheet
1
PCB Relay
A Cubic, Single-pole 10A Power Relay Small size and light weight · 19.6 Ч 15.6 Ч 15.6 mm, 7.5g High Insulation · Dielectric strength 2,000V · Withstand impulse voltage 4,500V High heat resistance and tracking performance · UL class-F available (-CF model) · IEC60335 GWT compliant · Tracking resistance CTI>250 Environmental friendly (RoHS compliant)
G5LA
Ordering Information
  • Тип реле: Power
  • Coil Voltage VDC Nom: 24 В
  • Contact Current Max: 10 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 24 В
  • Coil Resistance: 1.6 кОм
  • Contact Configuration: SPDT
  • Coil Type: DC Coil
  • Coil Current: 15 мА
  • Nom Operating Power: 360 мВт
  • Relay Mounting: PC Board
  • Внешняя длина / высота: 15.6 мм
  • Внешняя ширина: 19.6 мм
  • External Depth: 15.6 мм
  • Contact Current AC Max: 10 А
  • Contact Current DC Max: 10 А
  • Contact Voltage AC Max: 250 В
  • Contact Voltage DC Max: 24 В
  • Mounting Type: PCB
  • No.
    of Poles: 1
  • Operating Temperature Max: 85°C
  • Series: G5LA
  • Temperature Operating Min: -40°C
  • Type: Flux protection
  • Approval Bodies: VDE, CQC
  • Approval Category: UL Recognised
  • Coil Operating Lower Percent Limit: 10%
  • Coil Operating Upper Percent Limit: 75%
  • Contact Material: AgSnO
  • Contact Resistance: 100mohm
  • DC Coil Power
  • Dielectric Voltage Coil to Contact: 2000 В AC
  • Dielectric Voltage Contact to Contact: 750 В AC
  • No. of Mechanical Operations: 100000
  • Operating Time: 10 мс
  • Release Time: 5 мс
G5LA1E 24DC, G5LA 1E 24DC
На английском языке: Datasheet G5LA-1E 24DC - Omron RELAY, PCB, SPDT, 24 V DC
