Datasheet G5LE-14 12DC - Omron Даташит Реле, PCB, SPCO, 12 В DC — Даташит
Omron G5LE-14 12DC
Наименование модели: G5LE-14 12DC
19 предложений от 13 поставщиков
Промышленные/Универсальные Реле, Electromechanical Relay SPDT 8ADC/10AAC 12VDC 360Ω Through Hole
ЗУМ-СМД
G5LE1412DC
Omron
76 ₽
G5LE1412DC
Omron
81 ₽
ICdarom.ru
G5LE1412DC OMRON
Omron
от 101 ₽
G5LE-1412DC
Omron
Производитель: Omron
Описание: Реле, PCB, SPCO, 12 В DC
data sheetСкачать Data Sheet
PCB Relay
A Cubic, Single-pole 10-A Power Relay
I I I I I I I I I
New G5LE
Subminiature "sugar cube" relay with universal terminal footprint.
Conforms to VDE0435 (VDE approval: B250 Insulation grade), UL508, CSA22.2. Tracking resistance: CTI>250 (-VD type). UL class-F coil insulation model available (UL class-B coil insulation for standard model). High switching power: 10 A. Two types of seal available; flux protection and fully sealed. Withstands impulse of up to 4,500 V. 400-mW and 360-mW coil power consumption types available. Pre-soldered terminals.
  • Тип реле: Power
  • Coil Voltage VDC Nom: 12 В
  • Contact Current Max: 10 А
  • Contact Voltage AC Nom: 120 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 360 Ом
  • Contact Configuration: SPDT
  • Coil Type: DC Coil
  • Coil Current: 33.3 мА
  • Nom Operating Power: 400 мВт
  • Relay Mounting: PC Board
  • Внешняя длина / высота: 19 мм
  • Внешняя ширина: 22.5 мм
  • External Depth: 16.5 мм
  • Contact Current AC Max: 10 А
  • Contact Current DC Max: 8 А
  • Contact Voltage AC Max: 120 В
  • Contact Voltage DC Max: 30 В
  • Mounting Type: PCB
  • No. of Poles: 1
  • Operating Temperature Max: 85°C
  • Series: G5LE
  • Temperature Operating Min: -40°C
  • Approval Bodies: CSA and VDE
  • Approval Category: UL Recognised
  • Coil Operating Lower Percent Limit: 75%
  • Coil Operating Upper Percent Limit: 130%
  • Contact Material: AgSnO2
  • Current Rating: 79.4 мА
  • DC Coil Power: 400 мВт
  • Количество выводов: 5
  • Operating Time: 10 мс
  • PCB Hole Diameter: 1.3 мм
  • Release Time: 5 мс
  • Switch Current Max: 8 А
  • Switching Voltage AC / DC Max: 125 В DC
  • Switching Voltage AC / DC Min: 250 В AC
  • Вес: 12 г
Дополнительные аксессуары:
  • Omron - G5LA-14 12DC
G5LE14 12DC, G5LE 14 12DC
На английском языке: Datasheet G5LE-14 12DC - Omron RELAY, PCB, SPCO, 12 V DC
