Datasheet G5LE-14 24DC - Omron Даташит Реле, PCB, SPCO, 24 В DC — Даташит
Наименование модели: G5LE-14 24DC
Купить G5LE-14 24DC на РадиоЛоцман.Цены — от 50 до 112 ₽18 предложений от 12 поставщиков Промышленные/Универсальные Реле, Power Relay 24VDC 8DC/10AAC SPDT( (22.5mm 16.5mm 19mm)) THT | |||
| G5LE1424DC Omron | от 54 ₽ | ||
| G5LE1424DC Omron | 112 ₽ | ||
| G5LE-14-24DC Omron | по запросу | ||
| G5LE1424DC | по запросу | ||
Производитель: Omron
Описание: Реле, PCB, SPCO, 24 В DC
PCB Relay
A Cubic, Single-pole 10-A Power Relay
I I I I I I I I I
New G5LE
Subminiature "sugar cube" relay with universal terminal footprint.
Conforms to VDE0435 (VDE approval: B250 Insulation grade), UL508, CSA22.2. Tracking resistance: CTI>250 (-VD type). UL class-F coil insulation model available (UL class-B coil insulation for standard model). High switching power: 10 A. Two types of seal available; flux protection and fully sealed. Withstands impulse of up to 4,500 V. 400-mW and 360-mW coil power consumption types available. Pre-soldered terminals.
- Тип реле: Power
- Coil Voltage VDC Nom: 24 В
- Contact Current Max: 10 А
- Contact Voltage AC Nom: 120 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 1.44 кОм
- Contact Configuration: SPDT
- Coil Type: DC Coil
- Coil Current: 16.7 мА
- Nom Operating Power: 400 мВт
- Relay Mounting: PC Board
- Внешняя длина / высота: 19 мм
- Внешняя ширина: 22.5 мм
- External Depth: 16.5 мм
- Contact Current AC Max: 10 А
- Contact Current DC Max: 8 А
- Contact Voltage AC Max: 120 В
- Contact Voltage DC Max: 30 В
- Mounting Type: PCB
- No. of Poles: 1
- Operating Temperature Max: 85°C
- Series: G5LE
- Temperature Operating Min: -40°C
- Approval Bodies: CSA and VDE
- Approval Category: UL Recognised
- Coil Operating Lower Percent Limit: 75%
- Coil Operating Upper Percent Limit: 130%
- Contact Material: AgSnO2
- Current Rating: 79.4 мА
- DC Coil Power: 400 мВт
- Количество выводов: 5
- Operating Time: 10 мс
- PCB Hole Diameter: 1.3 мм
- Release Time: 5 мс
- Switch Current Max: 8 А
- Switching Voltage AC / DC Max: 125 В DC
- Switching Voltage AC / DC Min: 250 В AC
- Вес: 12 г
Дополнительные аксессуары:
- Omron - G5LA-14 24DC
G5LE14 24DC, G5LE 14 24DC
