Datasheet G5Q-1A4EU 24DC - Omron Даташит Реле, PCB, SPNO, 24 В DC — Даташит
Наименование модели: G5Q-1A4EU 24DC
![]() Промышленные/Универсальные Реле, Electromechanical Relay SPST-NO 5(NO)/3(NC)ADC/10(NO)/3(NO)ACA 24VDC 2880Ω Through Hole | |||
G5Q1A4EU24DC Omron | 50 ₽ | ||
G5Q1A4EU24DC Omron | 53 ₽ | ||
G5Q1A4EU24DC Omron | 62 ₽ |
Производитель: Omron
Описание: Реле, PCB, SPNO, 24 В DC
R
PCB Relay
Compact, High Isolation Relay H Compact single pole relay with high
isolation between coil and contacts
G5Q
- Тип реле: Power
- Coil Voltage VDC Nom: 24 В
- Contact Current Max: 10 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 2.88 кОм
- Contact Configuration: SPST
- Coil Type: DC Coil
- Coil Current: 8.3 мА
- Nom Operating Power: 200 мВт
- Relay Mounting: PC Board
- Внешняя длина / высота: 15.8 мм
- Внешняя ширина: 20.3 мм
- External Depth: 10.3 мм
- Contact Current AC Max: 10 А
- Contact Current DC Max: 10 А
- Contact Voltage AC Max: 277 В
- Contact Voltage DC Max: 30 В
- Mounting Type: PCB
- No.
of Poles: 1
- Operating Temperature Max: 105°C
- Series: G5Q
- Temperature Operating Min: -40°C
- Approval Bodies: UL, CSA, VDE
- Contact Material: Ag Alloy
- Contact Resistance: 100 MOhm
- Current Rating: 8.3 мА
- DC Coil Power: 200 мВт
- Dielectric Strength VDC: 4000 В AC
- Insulation Resistance: 100 MOhm
- Mechanical Life: 10,000,000 Operations
- No. of Mechanical Operations: 10000000
- Operating Time: 10 мс
- Release Time: 5 мс
- Switch Current Max: 10 А
G5Q1A4EU 24DC, G5Q 1A4EU 24DC
